SeaFoam?? will it work
Old May 29, 2008 | 08:01 PM
dukie's Avatar
I have a 88 vert with a 305tbi. Last year I put it away while it was running poorly. I will start and run/idle great. It after it warms up stutters and will only drive if you flutter the throttle. I am putting in new plugs pcv air filters etc. I was told to throw in some seafoam to the gas.. Is this a good thing to do or will it make my car run worse??
Old May 29, 2008 | 08:53 PM
red92firebird's Avatar
Car: 1998 Mustang GT
Engine: 4.6L
Transmission: T-45
Re: SeaFoam?? will it work
Use with confident.
Old May 29, 2008 | 09:06 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Engine light coming on?
Old May 29, 2008 | 09:26 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
stuff works great! but the tank is not the best place. pull off one of the vacuum lines that lead to the intake manifold and let it suck half of the can in. Then do half of what is left in the tank and the other half right on the TB blades to clean them up. Real easy and after you do all that. TURN it off for five minutes.... then turn it on and go for a long 20 min highway run and you'll be smoking for awhile but it will clean it all out real nice : )
Old May 29, 2008 | 09:57 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
What does your fuel injector spray pattern look like when its running good? How about when its running poorly? Have you checked fuel pressure yet?
Old May 30, 2008 | 06:59 AM
dukie's Avatar
I haven't really spent a ton of time on it as of yet. However this weekend I am taking it out of storage and want to get out far a first ride. I will check these things and will report back... and no engine light on.. just running rough while in drive==under load. thanks
Old May 30, 2008 | 08:13 PM
dukie's Avatar
I bought the stuff today for the tune up.. You know plugs cap rotor etc.
I also bought a spray made by (or for GM) called Cleans.
I guess spray while running and then it will clean out any gunk.
I will let you people know how it works out.
Old May 30, 2008 | 09:11 PM
89RsPower!'s Avatar
you got a new fuel filter too right?
Old May 31, 2008 | 10:26 AM
dukie's Avatar
yes, I am taking it to a buds with a hoist to do that part next week.
Old May 31, 2008 | 11:13 AM
mxcrazed's Avatar
Car: 87 firebird none soon
Engine: None
Transmission: none
Axle/Gears: 2.73 10 bolt
sea foam it while the engine is warm sounds like the problem lies in your dissy
Terrell351
Jun 13, 2021 01:13 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Vintageracer
Jan 10, 2020 05:33 PM
Jk_Under
Aug 17, 2015 03:08 PM
Fronzizzle
Aug 17, 2015 02:52 PM
