Small Victory Today
Old Jun 7, 2008 | 10:43 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
Transmission: gto t56 (mn12)
Small Victory Today
Today I did the impossible. Well that's what everyone told me and they had good reason to. I'm going el cheapo on my 350 rebuild and the number one connecting rod had spun a bearing. So I needed a refreshed crank and a new piston and connecting rod for the number one cylinder.
Because this was el cheapo I didn't pull the drivers side head. I tore everything out the bottom of the block. The problem comes in when I had to stuff the new piston back into the block from the bottom. I never measured the bore distortion at the bottom but I'm sure there was some.
I figured i could use one of those spring steel type ring compressors and then push it up from the bottom. Well of course the ring compressor wouldn't fit in between the main webs. So I put the piston in the bore until the top ring touched. Here comes the crazy part. I used both hands and all 10 fingers to manually compress the rings and push the piston up.
I'm still blown away that I got the piston to fit and I'm amazed at how cheap I am going on this engine. HAHA! Seriously Im not normally this stupid or cheap. Check it out.
Old Jun 7, 2008 | 02:13 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Small Victory Today
Old Jun 7, 2008 | 02:22 PM
Stephen's Avatar
Car: 87 GTA
When I read your post, I got thge impression that you were doing #1 ONLY, and with the engine still in the car!
Like you were doing it from under the car, engine still in, laying on your back!
Old Jun 8, 2008 | 10:29 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
^^^^^ Yea I'm going to replace one piston and connecting rod every six months until I've done all eight. LOL!
I guess rebuild was the wrong word to use. I just need this engine to be running while I correctly rebuild the ls1 i want to put in. So every dime I spend on the 350 is one I can't put into the ls1. So if it lasts me another year I will be more than happy.
Old Jun 8, 2008 | 04:52 PM
89IROKCONVERT's Avatar
thats crazy i thought of that in my younger years but put it out of my head because everyone said it was impossible just goes to show nothing is impossible good show thanks for the knowledge ps how did you keep you caps straight if i dont mark things i will eventually move them and then im screwed
Old Jun 8, 2008 | 09:22 PM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
The main caps have an arrow cast into them pointing towards the front of the engine. When I took them out I just laid them next to each other in the order I took them out. Starting with the thrust bearing cap first.
On the rod caps I did the same thing but I laid them down in pairs. Two per main web. You could tell the orientation by matching them to the connecting rod and piston assembly that was still in the block.
Old Jun 8, 2008 | 09:26 PM
Comp788's Avatar
Car: 1982 Z28 & 1967 RR/SS 396
Engine: ZZ383 & 375hp 396
Transmission: T56 & factory TH400
Axle/Gears: 9" ford & 12 bolt 4.10
I sure hope you flushed out the oil galleys. Otherwise you'll be doing that again really soon. if you spun a bearing there will be metal partials all over the motor. Clean it out!
Old Jun 10, 2008 | 07:04 AM
FirehawkSS's Avatar
Car: 87 Firebird,
Engine: lq4
^^^^^ I put a new oil filter on. What more do you want? HAHA. Yea I tried to flush the oil galleys. I put some cleaner in and blew them out with an air nozzle from the oil pump feed hole. I'm not sure if that was good enough though. I bought a new oil pump as well so things should be decent.
Old Jun 10, 2008 | 08:44 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Hope you have the LS1 ready to go soon. . .
F-body driver
Mar 6, 2023 11:44 AM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
Amillionoh7
Sep 11, 2015 11:36 AM
TBRays98
Sep 6, 2015 05:05 PM
