heads
Old Jun 13, 2008 | 03:11 PM
84transamdude's Avatar
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
heads
tring to find find some cast iron heads with these specs so far have come up empty if any one could help or point in the right direction that would be great. It would be for a 350 block year 79.
170cc Intake Ports
64cc Combustion Chambers
2.020''/1.600'' Valves
1.460'' Valve Springs, .575'' Max Lift
3/8'' Rocker Studs
Straight Plug
Old Jun 13, 2008 | 03:17 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: heads
Any reason why you want those specific specs? 170 intake ports are teeny tiny, but 2.02/1.160 valves are big. Seems like a bit of a mismatch. Did somebody who "knows their stuff" recommend these specs?
That sounds like an old stock fuelie head or an entry level aftermarket head of an old design. I wouldn't recommend following that path.
Old Jun 13, 2008 | 03:52 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: heads
edelbrock has a top end kit with those spec heads and i'm trying to save money without having to get aluminum heads. if you know something else that will work with that cam/intake i'm all ears.
http://www.jegs.com/i/Edelbrock/350/2098/10002/-1
Old Jun 13, 2008 | 04:14 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: heads
So basically you have that kit, without the heads, so you want heads to use in that application?
Or do you not have the kit yet at all?
Old Jun 13, 2008 | 04:34 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: heads
how much are you looking to spend on the heads? the only stock head that are worth a **** are the vortec heads..u could pick up some patriot performance heads pretty cheap about 800 bucks...good for a fun lil street motor....
Old Jun 14, 2008 | 04:41 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: heads
i do not have anything yet. just not sure what works with what and i want to build a motor that will have close to 400 hp
Old Jun 14, 2008 | 12:32 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The cam in that Edelbrock kit is a peaky, no-torque paperweight. You can, and should, do much better.
Heads & intake:
http://www.sdparts.com/product/SD806...formerRPM.aspx
Cam:
Comp XE274 flat tappet hydraulic.
Assuming proper compression, easily over 400 HP, and will be much more street friendly.
Old Jun 14, 2008 | 03:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Re: heads
There we go. Don't bother buying edelbrocks kits. They are great at marketing and poor at putting together combos. They make excellent intake manifolds, end of list
Five7 kids idea is a good accurate one that's been done to death (a good thing in this case). Proven time and time again.
Old Jun 14, 2008 | 03:41 PM
five7kid's Avatar
A slightly better choice:
http://www.sdparts.com/product/SD806...RPMAirGap.aspx
Old Jun 14, 2008 | 04:16 PM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: heads
Heads & intake:
Cam:
cant find that cam. The head and intake combo does not look bad thou.
Old Jun 14, 2008 | 04:40 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: heads
XE274h-10
http://store.summitracing.com/partde...3&autoview=sku
Old Jun 15, 2008 | 04:31 AM
Car: 84 Trans Am
Engine: 383 Stroker
Transmission: Th350
Re: heads
five7kid is this the combo you have in your car?
Old Jun 15, 2008 | 01:38 PM
Car: 91 RS
Engine: 350 vortec
Re: heads
it is the combo i have in my car... i have the airgap instead of the rpm and the xe274 with vortecs i was very impressed
Old Jun 16, 2008 | 12:28 PM
five7kid's Avatar
I'm still running the ZZ4 clone with ported World 305 heads.
Old Jun 17, 2008 | 07:53 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: heads
I have that cam, along with a set of 200cc/64cc World heads, Edelbrock RPM intake, and a 750 Holley. Its a VERY good combo, and a great street cam. Sounds nice and has some lope, but still has good manners and makes lots of torque starting around 1800 or so in my 350.
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
