Pushrod recommendation...
Old Jun 21, 2008 | 05:41 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Can anyone recommend a decent set of pushrods for use with a factory roller cam setup? I'm unsure what length or diameter the factory used..
Old Jun 21, 2008 | 10:50 PM
89RsPower!'s Avatar
Re: Pushrod recommendation...
anybody????
Old Jun 22, 2008 | 06:44 AM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
You're going to have to do much the same as the rest of us have to do,
SEARCH!
Old Jun 22, 2008 | 01:50 PM
jersyboyy's Avatar
Car: 85 Camaro
Engine: forged 383 11:1
Transmission: T56 TDP STAGE 2
Axle/Gears: 99 ws6 3.42 posi rear
Dude if you dont have anything useful to say shut up. If you did all the hours of searching and you know the information let the guy in on it. This is a topic im still researching so I cant give you any ideas but this guy about me deserves to bac kto kindergarden and learn how to share.
Old Jun 22, 2008 | 02:39 PM
89RsPower!'s Avatar
SEARCH!
thanks for the worthless reply, I did search and couldn't find the answer I'm looking for which is why I made this post, I figured someone on here would know the length of a factory roller pushrod off the top of their head. I think that it may be 7.200 but I would like a comfirmation from someone who actually knows for sure before I order parts..
Old Jun 22, 2008 | 05:10 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
If you did search and cant find it, then please post that you searched. People will be more likely to help.
Roller cam engines came with 7.200" long, 5/16" diameter, .080" wall thickness pushrods. Stock replacement mild steel Manley pushrods would be part number 25717-16. High performance hardened chrome-moly Manley pushrods for use with guideplates would be 25733-16.
Old Jun 22, 2008 | 05:11 PM
tpi user's Avatar
im 99.5 percent sure they are 7.200 if everything is pretty much stock in the valvetrain. i even think if you have a summit or jegs catalog it lists the lenghths of the pushrods for an 87 up oe roller setup
Old Jun 22, 2008 | 09:07 PM
89RsPower!'s Avatar
Thanks! I'm not sure which I should go with, I'm running an lt1 roller cam with factory roller lifters from the lt1 with world products sr torquers that came with guideplates and roller rockers installed. Would I need the chrome-moly ones or will factory replacements do?
Old Jun 23, 2008 | 10:15 AM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Get a $12 pushrod length checker, and a sharpie, and double check the length needed. You'll use the tool again later.
Then yea, get the chro-moly ones.
Old Jun 24, 2008 | 12:21 AM
Kevin91Z's Avatar
You can use either part number I listed with guide plates, they're both hardened.
Old Jun 24, 2008 | 04:33 PM
89RsPower!'s Avatar
Thanks guys!
Old Jul 29, 2008 | 09:19 AM
GMPARTSGUY's Avatar
Car: 1986 trans am
Axle/Gears: 373 9 bolt
SEARCH!
That kind of answer is exactly why I never go on this site anymore .............
Old Jul 29, 2008 | 11:55 PM
86z/92rs's Avatar
Car: 86Z/92 RS Camaro
Engine: 357 vortec finished. need tuning
Transmission: Still works
Axle/Gears: need 3.73
This is the route the best route to go with. Went with the the trick flow hardened push rods with guide plates.
Old Jul 30, 2008 | 01:42 AM
EvilCartman's Avatar
Car: '82 Z28
What did you do, come back and search for a "search!" post just to say you never come back when you apparently do?
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
slowsi
Oct 18, 2015 08:49 PM
mfp189
Sep 27, 2015 09:25 AM
SLNTSCPE
Aug 22, 2015 09:15 PM
