I'm pretty sure its the starter....
Old Jun 23, 2008 | 10:10 AM
Nasphreak29's Avatar
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
This car has just been problem after problem since I bought it -_-'
Anyway, yesterday(while on a date to) My car wouldn't start up when we came back from eating. It had a strong attempt at turning over first and then it just went to "click click click". It had been fine all day starting up like usual right until that point
Before I bought the car though, the man replaced the starter in it(had to wait a week to get it because of that). Which makes me think its not the starter..or they didn't fix the problem that caused the starter to go out.
Now a little info about my car. Its a 1988 Iroc-Z 305TPI. It idles pretty high at around 1500RPM in park and like 800-1100 in Drive or any other gear. Its been overheating lately cause I still haven't replaced the secondary fan motor but it has only ever gotten over 220 maybe 4times? Its always been a little hard to startup anyway but it started up strong.
Two owners before me the guy shaved the door handles and really ****ed the wiring in the radio area because of it.
Any ideas other than the start or is that what is defiantly is?
Old Jun 23, 2008 | 10:26 AM
mario82z28's Avatar
Car: 82' z28/03' eddie bauer explorer
Engine: 355-395hp/4.6v8
Transmission: Built 700R4/5speed auto 4x4
Axle/Gears: 3.42LSD/3.73
Re: I'm pretty sure its the starter....
sounds more like the battery is not keeping its charge and if its idling too high id try the tps id definitely get that fan motor fixed or your going to end up with a lot more problems than your battery
Old Jun 23, 2008 | 10:45 AM
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
I just replaced the battery maybe a month ago because my stereo system killed it and according to the gauge it had plenty of juice to turn over. And Im just waiting on my paycheck wensday to replace the Fan motor.
TPS? O.o Im kinda new to working on engines(still in the learning process) so whats that?
Old Jun 23, 2008 | 11:21 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
throttle position sensor, don't worry about that yet though, get the car running and go from there. IF the battery is good and charged check the connections on the starter and make sure they are clean/tight, also check the ground to the block and the connections to the battery. If the starter and battery is good and the connections are clean and tight it will turn over. If the battery itself is good but discharged figure out what caused that, wether it be a bad alternator, or something causing a parasidic draw with the engine off. When you say according to the gauge it has plenty of juice to turn the engine over, are you saying you installed an amperage gauge or are you talking about the factory voltage gauge? It can still have proper voltage and not enough amperage to have a hope in hell or turning the starter.
Old Jun 23, 2008 | 02:26 PM
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
Ok...apparently it IS the battery. Because my doors wouldn't open and I had to crawl in through the trunk to get it off the wrecker.
The alternator works fine at least I'm assuming because I drive normally everyday to work, which is about a 15m drive, then I drive to my other job about 5m then home about 15m drive. Giving the alternator about 30m to actually charge the battery a day. Now, I didn't work Friday, Saturday, and I used it Sunday to go to the movies and then taco bell(her choice by the way :P im not cheap lol). Its about a 20m drive to her house, and then another 30 to the movies from there. Now, from the movies to Taco Bell its only a 2m drive(unless you hit one of the 4 red lights every quarter mile). And it started up fine between The movies and Taco Bell.
So the alternator didn't have time to charge it between the movies and Taco Bell. But the question is..what would make a battery not hold a charge? Its only about 1 month old and wasn't new when I bought it(low on money at the time).
Old Jun 23, 2008 | 02:41 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
get the alternator tested at advance auto or autozone. my first replacement alternator caused issues because it didnt put out enough voltage (only 10V after i got it tested) which means that the battery was slowly being run down and i had similar symptoms.
Old Jun 25, 2008 | 11:47 AM
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
I had one of my dads friends look at it and he said theres a short between the battery and the alternator but can't tell me anything else cause he doesn't know much about electronics.
How would I further check this..and how would I fix it? O.o
Old Jun 25, 2008 | 12:49 PM
parkerchance's Avatar
use a multimeter on each side of the fusible link that goes to the alternator. check for continuance.
Old Jun 25, 2008 | 01:42 PM
safemode's Avatar
Car: camaro rs
Engine: 305 tbi and 350 on stand
Transmission: 4spd auto
overheating will damage the varnish in the coils of the alternator and the starter (causing a short and thus, a dead section in the coil). You may have damaged both during your overheating. I wouldn't consider "overheating" to be less than 240 though. 220 is fairly normal operating range. Up in the red definitely has the ability to damage the starter.
Wire up your secondary fan to a toggle switch in the car or replace the temp switch.
Old Jun 25, 2008 | 05:57 PM
Car: 87 Iroc-Z
Engine: 5.7L
Axle/Gears: 3.27 BW
Alright...well I went up to advance auto parts and it started just fine when I put the new battery in it....so I drove the car back to Advance Auto Parts and had them check out everything and they said that its all good. When I explained to them about the other battery they said that was probably it.
I had bought the battery used because the battery that came in the car went completely out after I had put a new stereo in there...so after removing the stereo I bought the used battery(cause I was broke at the time). And they informed me just now that it was most likely the used battery.
So all I need to do is fix the fan motor and then the car should be good for a while. -_-' Im still gonna save up my money and plan on buying a better one and probably turn this one into a LS1 conversion..or a 350 conversion..or just use it for parts lol ill figure out something when the time comes xD
Old Jun 25, 2008 | 06:07 PM
chevylove91's Avatar
I need some help I have a 91 camaro z28 5.7L 350 and it will not crank up for about a hour after it has been driven. It turns over but it with not fire up. Can anyone offer some advice.
Galaxie500XL
Feb 1, 2020 04:53 AM
Elephantismo
Feb 13, 2019 12:51 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
budowski
Carburetors
Oct 2, 2015 10:16 AM
ramicio
Sep 28, 2015 01:18 PM
