Need help with pushrod length checker..
Old Jun 27, 2008 | 03:33 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
So I got a pushrod length checker to figure out what length pushrods I need. It's plastic and looks like a rocker and slips over the stud in place of a rocker. Directions say with the lifter on the round base circle to position the checker over the stud and see if it contacts the pushrod and valve evenly at the same time and if not to measure the difference. Which lifter is in the proper position to take this measurement with the crank and cam sprockets dot to dot? I assume I just set the checker on top of the stud with no preload on the lifter correct?
Old Jun 27, 2008 | 05:00 PM
89RsPower!'s Avatar
Re: Need help with pushrod length checker..
Also does anyone know if LT1 roller lifters are the same height and everything as the lifters used in our roller engines?
Old Jun 27, 2008 | 05:06 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Just roll the engine over until you're on the base circle on one lobe, then check that one.
Those are junk though. I have one and only used it once, and realized how hokey it was.
Get the one that looks like a pushrod, with a nut on it's middle area. You adjust it's length, and check witness marks.
Sorry, I don't know LT1 lifters vs normal.
Old Jun 27, 2008 | 06:05 PM
89RsPower!'s Avatar
It looks really close, maybe the thickness of a matchbook in difference, didn't get a chance to measure it yet since my feeler gauges are at home, will such a small be a problem?
Old Jun 27, 2008 | 06:56 PM
89RsPower!'s Avatar
i just measured the gap between the valve top and the checker and it's about .05, with one of my roller tipped rockers on it appears to be perfect.. Do I really need 7.15 pushrods? Do they even make them?
Old Jun 27, 2008 | 08:34 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I am with Sonix I have one also to date every motor I oput together even stock the tool is wrong on push rod size the best way is to use an adjustable push rod and a light spring with the rocker you plan on using mark the top of the vaulve roll the motor thru you want it to be centered with the least amount of motion.
Old Jun 27, 2008 | 08:45 PM
89RsPower!'s Avatar
No idea where to get one locally and I don't want to have to pay summits fee to order one, I guess I'll just order stock length, they really close anway..
Old Jun 28, 2008 | 02:17 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Manley 25741-16's are 7.150" long pushrods. I have them in my engine now. Or you can get part number 25717-16 pushrods, which are 7.170" long and are made for stock to mild roller cam engines.
We also sell that type of pushrod length checker, and I agree its kind of screwy. If the checker hits the valve first, then you need longer pushrods. If it hits the pushrod first, then you need shorter pushrods.
LT1 roller rockers are made for centerbolt valve covers and "should" fit our engines with no problem. But dont take my word for it, I dont know if the LT1's use a different type of rockers.
Old Jun 28, 2008 | 01:38 PM
89RsPower!'s Avatar
As far as the roller rocker compatability, they are gen 1 sbc roller tipped rockers. I was asking if the lifters were the same height etc. Thanks.
wigmobile
Feb 26, 2025 02:56 PM
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
mfp189
Sep 27, 2015 09:25 AM
Scorched1984
Sep 15, 2015 03:42 PM
