rich smelling exhaust
Old Jul 12, 2008 | 12:08 AM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
my exhaust stinks like hell. i know the valve seals are getting pretty stingy but what else could cause it? it smells like exhaust but stronger. im runnin a true dual with force mufflers if that helps. thanks
Old Jul 12, 2008 | 01:27 PM
Engine: 355
Re: rich smelling exhaust
any ideas?
Old Jul 12, 2008 | 01:29 PM
TADailyDriver's Avatar
Car: 1988 Trans Am, 2005 Sierra 2500
Engine: Vortec 357
Transmission: Built TH700R4 with 26-2800 Stall
Axle/Gears: GM 10 bolt 3.73 Posi
is you egr valve working correctly? if not you could be running rich which gives you a bad smellin exhaust. Valve seals are you best bet tho. Mine smells like **** as well only cause my egr valve doesnt work rite n i have no cat.
Old Jul 12, 2008 | 05:45 PM
Engine: 355
i dont have an egr anymore and dont have cats either.. anyway to lean it out or am i stuck w it/
Old Jul 12, 2008 | 07:09 PM
Engine: Vortec 357
if you bought an aftermarket fuel pressure regulator you could do it that way, or try advancing your timing that may help as well. Im going to advance my timing tommrow so i will let you know how it turns out.
Old Jul 12, 2008 | 08:21 PM
Engine: 355
i have my timing advanced already and still stinks, how woul a fuel regulator help the smell?j.w. and how hard are they to hookup
Old Jul 12, 2008 | 08:27 PM
impaled's Avatar
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
having no cat is always going to make the exhaust smell stronger. tuning can definitely impact the richness.
you didnt state your induction... so i am assuming that it is carbed.
unless you are running way too high of of pressure (>10 PSI) i do not think that the regulator will lean it out at all, although running too much pressure through a carb could potentially cause issues.
i would stay away from Mr. Gasket as far as fuel parts go. i had a Mr. Gasket FPR and it failed on me after a month or two, and i have their fuel pressure gauge and it sucks. i would go for a holley FPR.
Old Jul 12, 2008 | 09:53 PM
Engine: 355
ya i have a carbed car edelbrock carb. im not sure what psi in fuel im running. should i slap a gauge on it or leave it be?
Old Jul 13, 2008 | 09:43 AM
Engine: Vortec 357
The only way to get rid of that rich smell is to put a high flow cat back on which is what im doing because it will filter some of the stuff in your exhaust out so it wont stink as bad. And im sick of having all the black shoot on my rear bumper, especially cause i have a white car.
Old Jul 13, 2008 | 10:51 AM
Engine: 355
ya i bet man. does anybody know how to mount a feul pressure gauge in a cowl hood?
Old Jul 13, 2008 | 01:24 PM
Engine: Vortec 357
Ill ask my friends dad he has a camaro and he mounted one under the hood, so gimme a day or so and ill let ya know. Also i just adjusted my timing. I thought it was at 0 but when we put the light on it, it was at +12!!!! i bumped it down to +4 and it runs better and the exhaust smells alot better.
Old Jul 13, 2008 | 02:55 PM
Engine: 355
alright ,man thanks i mite go adjust my timing then
Old Jul 13, 2008 | 08:20 PM
Engine: Vortec 357
heres a fuel pressure regualtor to be used to 305-350 tbi engines on ebay. heres the link: http://http://cgi.ebay.com/ebaymotor...3756.m20.l1116
Old Jul 13, 2008 | 09:07 PM
impaled's Avatar
i would definitely put a gauge on there. i havent had an edelbrock carb, but for my holleythere is a spot for the gauge where the fuel rail goes into the carb.
i would only get a FPR if the pressure is too high.
Old Jul 13, 2008 | 11:49 PM
Engine: 355
i dont think my edelbrock has a spot for a pressure gauge. whats the normal psi on fuel for a 350?
Old Jul 14, 2008 | 08:19 AM
wanab03ss's Avatar
Car: 87 GTA
Engine: 385 sbc
Axle/Gears: 2.73 posi
You can run the guage on the fuel line, you should be anywhere from 5-7 psi of fuel pressure.
Old Jul 14, 2008 | 09:11 AM
impaled's Avatar
+1. make sure to get a liquid filled gauge, otherwise all it will do is bounce around and you wont be able to tell your pressure.
i would also stay away from Mr. Gasket. i have had nothing but issues with any of their parts.
Old Jul 14, 2008 | 01:05 PM
Engine: 355
ok ill try that do they have ones with filterssbilt in i have an inline filter and id look weird with it tapped into it with alot of things on fuel line
Twin_Turbo
Mar 14, 2016 10:10 PM
earlpote
Sep 12, 2015 11:55 AM
Glowsock
Sep 11, 2015 11:09 PM
89fast5oh
Sep 8, 2015 09:55 AM
Jk_Under
Sep 8, 2015 08:13 AM
