valve cover make a BIG mess?
Old Jul 17, 2008 | 09:56 PM
billybob6110's Avatar
Car: 1984 chevy camaro
Engine: 355
Transmission: turbo 350 2800 stall
Axle/Gears: 3:73 detroit locker posi
ok guys as i posted before about my dipstick issue now i seem to think this might be my issue all along. i drove my car to work today, and oil was dripping off the inspection cover. the oil filter and the driver side block behind the valve cover is "wet" now would a bad gasket make it leak like a siv or is it sumthing else? i thought maybe intake valey but the passenger side behind valve cover and block is dry... any suggestions would be great!
Old Jul 17, 2008 | 10:04 PM
loneroad's Avatar
Car: 90RS Conv.
Engine: 383 w/ small shot
Transmission: th400
Axle/Gears: moser 9in
Re: valve cover make a BIG mess?
are you running a mech oil pressure guage? I pinched the line under the valve cover b4.
or a high pressure oil pump pushing oil from under your distributor
Old Jul 17, 2008 | 10:09 PM
Engine: 355
ya im running the stock oil pressure gauge.. and stock oil pump.. its only the one side and it leaks alot...i have chrome valve covers and spreaders and using the t-handle hold downs. is it possible i over tightend it and its leaking now? only leaks when i run it hard.
Old Jul 17, 2008 | 10:13 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
ive smooshed the cheap cork gaskets out already. i only buy the steel and rubber ones now... they are so worth the extra$$$$
Old Jul 18, 2008 | 12:06 AM
Engine: 355
ok i looked with a mirror and light the valve cover is dry but my intake rubber gasket is sitting fudged up and its wet. lucky me!would a leaking intake give me a crappy and missing idle, and low oil pressure too? also im gna be fixing it whats the best way to get it to seal properly so i dont run into it again
Old Jul 18, 2008 | 01:04 PM
Engine: 355
anybody
Old Jul 18, 2008 | 05:49 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
takje those rubber end pieces and throw them away. That is the reason noone uses them. laydown a nice thick bead of rtv instead.
Old Jul 18, 2008 | 07:50 PM
Engine: 355
so dont use the rubber piece in front or rear? and rtv will be enough to seal it?
Old Jul 18, 2008 | 08:20 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
yes, its far better than the rubber pieces.pull the manifold clean all your surfaces, put your new intake gaskets on, and run anice thick bead of rtv on the front and back of the block. then get some one to help you sit the intake on and tork it down.
Old Jul 18, 2008 | 08:38 PM
Engine: 355
k thanks man u been a real help. one last question. should i after cleaning the surfaces put gasket sealer down first then the gasket, let it set up for bout 10 mins then put gasket sealer around the coolant holes and then the valleys in front and back. than put intake on?
Old Jul 18, 2008 | 08:45 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
i usually put a light bead around the water passages. that is enuff to hold the gasket in place..
youll be up in no time..... after you get it torked down, wait awhile before running it. let the rtv cure.couple hours or so.
Old Jul 18, 2008 | 08:55 PM
loneroad's Avatar
Car: 90RS Conv.
Transmission: th400
if you have your block all painted and pretty. run a piece of tape along the bottom edge of the valley. the rtv is gonna smoosh out a bit when putting the intake on. the tape will catch the rtv and give you a nice clean edge.
Old Jul 18, 2008 | 08:59 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i usually let mine set the recomended 24 hrs. its good insurance for all the stuff youll be pulling off if you run it pre-maturly. P.S. the rubber ends are GARBAGE! build 2 "great walls of china" and be done with it.
Old Jul 18, 2008 | 09:31 PM
Engine: 355
thanks guys! im gna rip it apart tomorrow and let it sit prob a full day or so so i dont get in a jamble again
Old Jul 19, 2008 | 11:50 AM
Engine: 355
ok well................i took off valve covers dizzy cap and started lookin back there. the intake aint leakin its tight, valve covers were kinda iffy, but the the thing leaking was the damn oil sending unit it wasnt even tight!!!! it spun when i touched it wtf. so i tightned it and gna give it a try, gimme lucky!
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
blackd-out z28
Aug 15, 2015 08:18 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
