Finishing My Engine Today
Old Oct 5, 2008 | 10:47 AM
toddly24's Avatar
Hey guys, just saying whats up and posting a little about what I've been doing.
1984 T Top Camaro
350 out of a silverado
Hooker Headers
Demon 750 mechanical
SDPC Vortec Heads
Lunati 60103
3 inch exhaust
Edelbrock performer intake
Going all together today. Do you think I'll be impressed with the performance?
Old Oct 5, 2008 | 04:12 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Depends upon what it takes to impress you, but I think I'd be impressed.
The only mismatch I see is the intake - you're giving up 700 RPMs of cam powerband.
Old Oct 5, 2008 | 05:25 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Re: Finishing My Engine Today
I think you'd be much happier with an Edelbrock RPM or Weiand Stealth intake over the basic Performer. The RPM/Stealth will match that cam much better.
I recommend the Stealth over the RPM just because of the carb you have - the RPM has the brake vacuum fitting right under the secondary accelerator pump, and it sits so close to the carb that its basically useless unless you use a carb spacer.
The Stealth does not have thise problem, and the performance is about the same as the RPM.
Old Oct 6, 2008 | 02:06 PM
toddly24's Avatar
Yeah, I'm ordering a new intake right now... trying to decide between the stealth and the rpm air gap
Old Oct 6, 2008 | 02:43 PM
10secondhopeful's Avatar
Car: '84 Z28
nice, well put it this way, it will be alot different then what it used to be. should throw you in your seat pretty nice =D
don't hurt yourself lol
Old Oct 6, 2008 | 04:55 PM
Air_Adam's Avatar
Go with the Stealth (theres a 'Stealth Air Strike' too, which is an air gap style intake)
The Stealth manifold avoids alot of the problems of using a dual feed Holley/Demon carb that the RPM has. The performance is the same between the two, you won't notice any difference there. I've used the RPM Air Gap and the regular Stealth - the Stealth is a much better choice with the carb you are using IMO.
Old Oct 6, 2008 | 07:29 PM
toddly24's Avatar
Awesome, thanks guys. One question... will it even come close to the performance of like an lt1? According to digital dyno it's over 400hp... but who knows. If it's not good enough... blower? I want to stick myself in the seat and not get out of it.
Old Oct 6, 2008 | 08:19 PM
Air_Adam's Avatar
You should be in the 350-400 REAL hp range, so you shouldn't have any problem with stock or mild modded LT1 cars.
Old Oct 7, 2008 | 07:17 AM
toddly24's Avatar
Awesome that's what I'm looking for.
Old Oct 7, 2008 | 02:07 PM
five7kid's Avatar
My Camaro outruns stock LS1 automatics.
Old Oct 8, 2008 | 10:14 PM
toddly24's Avatar
Awesome... I love my camaro... even in it's hunk of crap glory. It's a real pile right now but it's coming along.
Old Oct 9, 2008 | 02:59 PM
toddly24's Avatar
Any ideas on what distributer would be the best for my setup? I've got a couple different ones but I have no idea. I'm thinking a mechanical advance one like used in a race car but I may be wrong.
Old Oct 9, 2008 | 05:10 PM
five7kid's Avatar
With a non-computer carb, you need a non-computer distributor.
Typical is a mechanical/vacuum advance type, many new HEI large cap types available, if you're using an ignition box, you can get a distributor that plugs right into it. I've got MSD parts on the 396, works great. When the MSD box got wet last season (away from home), I ran down to O'Reilly's and picked up an Accel HEI distributor and Super Coil, it ran fine with it (I just didn't have my 2-step rev limiter).
Old Oct 9, 2008 | 05:41 PM
toddly24's Avatar
So I need one with a vacuum advance also? I know some are available with mechanical advance only.
Old Oct 9, 2008 | 08:58 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Well if your going to be driving on the street id use one with a vac advance. The inexpensive accel that 5-7 mentioned is a realy good replacment peice I use them all the time. I like the weiand intakes my vote goes for the steath I just got a real good deal on the RPM siting under my hood.
Old Oct 9, 2008 | 10:50 PM
toddly24's Avatar
Yeah, it will see quite a bit of street time I guess. I have an old one with a vacuum advance but it needs rebuilt. I think I'll go buy a new one.
Old Oct 10, 2008 | 06:11 PM
Air_Adam's Avatar
If you have the coin, the MSD Pro-Billet distributor and a 6A or 6AL box is a very nice setup. The Pro-Billet dissy for the SBC can be ordered with a vacuum advance setup.
Thats what I have on mine (vac advance Pro-Billet and 6A box) and its fantastic, I love it!
Infested
May 22, 2018 11:56 PM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
InfinityShade
Aug 22, 2015 08:00 PM
Linson
Aug 21, 2015 02:12 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
