So upset my motor wont go in!
Old Oct 23, 2008 | 07:43 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
My 305TBI has the 700r4 attached.
Ive spent the past 6 hours wresteling to get it in, the motor/tranny are in generally the correct area. But the motor mounts on the engine are giving me huge problems, for around 4 hours, the drivers side is about right, a little beating and it will go in, but no matter what I try the passenger side doesent line up!
I have no idea what the problem is, I tried jacking up the tranny, try to level the engine out, does nothing. Ive tried having the leveler in different postions, ive tried moving the entire hoist in different directions and nothing has helped
If any one is in the Northern Virginia Area, id pay them 40$ to get it on!
I have no idea what the problem is and its extremely frustrating.
Old Oct 23, 2008 | 07:59 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Did you change the engine mount inserts?
Old Oct 23, 2008 | 08:08 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Re: So upset my motor wont go in!
Yes I did, put the energy suspension ones that hawks sells in.
Old Oct 23, 2008 | 08:18 PM
five7kid's Avatar
I suspect you got one side in backwards, so the tabs are hanging up the engine side mount.
Old Oct 23, 2008 | 08:33 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
The passenger side mount[engine] gets stuck on the top metal part of the mount[car]. I lifted the motor so both sides werent touching, and tried adjusting the position of the engine, but as soon as i lower it, I run into the same problem.
Old Oct 23, 2008 | 11:47 PM
five7kid's Avatar
Is the bellhousing hitting the firewall while you're trying to get the mounts lined up?
Old Oct 24, 2008 | 12:01 AM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
some pictures would really help..
Old Oct 24, 2008 | 04:38 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Without pictures i'd have to agree with 5.7kid. Same thing happened to me once. Drove me up the wall.
Old Oct 24, 2008 | 09:08 AM
kahless's Avatar
Car: 89 Firebird Formula
Engine: chevy 5.7 V8 TBI but carbed soon
Axle/Gears: no freakin clue lol
Try puttin the motor in first then the tranny. i was always told this was easier due to alignment issues with the mounts
Old Oct 24, 2008 | 06:22 PM
tryn2gofast's Avatar
i did the same thing i put 1 side motor mount in wrong. felt like pitching a hammer thru the windshield.
Old Oct 25, 2008 | 08:39 PM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
My friend came and worked some magic and we got it on, thank goodness.
It wasent backwards or anything.
Now I just think I stripped the power steering line and I cant remember what wires go to the starter, grrr.
Old Oct 26, 2008 | 10:35 AM
89RsPower!'s Avatar
start is very easy, they're all on the same harness and it's just about the only one that can even reach the starter, it will go kinda over the intake down the front of the engine by the pass side head and then run back, pretty easy to figure out because they are ring terminals, there will be one large one ruffly the same size as the possitive battery cable and goes on the big post on the solenoid that the positive cable connects too, the other goes on the small terminal. The same harness should have the connectors for both the knock sensor and the fan switch.
Old Oct 26, 2008 | 11:46 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Thanks man, ill look at it a little later today.
hydrolic144
Sep 8, 2015 06:55 PM
greenyone
Aug 29, 2015 11:08 AM
Randomtask2
Aug 26, 2015 03:34 PM
86White_T/A305
Aug 17, 2015 12:16 AM
slade5612
Aug 11, 2015 07:19 PM
