odometer stops and starts working
Old Oct 28, 2008 | 11:24 PM
Grizzlybear226's Avatar
Car: 1988 Trans am
Engine: 358
i just noticed today on my way home from school that my odometer had stoped but after about 5 mins it started again. Then it stoped again when i went out later on and didn't start working since then. My speedometer works fine even when the odometer stops working. I thought the two were connected to run the same speed. Do i need a whole new cable, what could be the problem? would like the mileage to be accurate
Old Oct 29, 2008 | 01:25 AM
Sonymaster20's Avatar
Car: 1992 Rs
Engine: 305 TBI
Transmission: 5-Speed
Axle/Gears: 3.08
Re: odometer stops and starts working
It could be your cable, while its spinning, it may be slipping in and out of the speedo behind it or where it inserts to the transmission that may be causing this. Although i've never had a problem, I have replaced my speedo cable because of noise, and it did seem a little weak at those points. it may also be the actual speedometer that is screwed up also.
Old Oct 29, 2008 | 07:15 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
An 88 TA should have an electronic speedo. If I'm incorrect, the following link will provide the fix for a cable-drive speedo head:
https://www.thirdgen.org/forums/faq-...-fix-pics.html
JamesC
Old Oct 29, 2008 | 09:44 PM
Car: 1992 Rs
Engine: 305 TBI
Axle/Gears: 3.08
oh, didn't even notice James thanks.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
TheExaminer
Aug 26, 2015 04:59 PM
Ginamariegault
Brakes
Aug 10, 2015 08:33 AM
kyle5647
Aug 7, 2015 03:08 PM
