Let's make this simple
Old Nov 18, 2008 | 05:48 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Is there a starter that has a straight bolt pattern and will also match up with a 168 tooth flexplate and still fit in the stock location?
I'll tap a hole if one doesn't exist.
Old Nov 18, 2008 | 01:15 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: Let's make this simple
Nope. That's an age old problem for us. Just get a 153 tooth flywheel, and drill/tap the hole for that (if the block doesn't have it).
Old Nov 19, 2008 | 05:33 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I'll just tap the existing hole and throw on a staggered pattern starter.
My mini wouldn't even touch the 153 when I originally had it on. Of course I was stupid enough to not check that when it was on the stand and easy to get to.
Old Nov 19, 2008 | 09:04 AM
Sonix's Avatar
Car: 1982 Trans-Am
You have a staggered hole drilled but not tapped?
Ok, if you do that, then you need the bigger bellhousing (from a truck), which will then not fit your 3rd gen tranny tunnel.
It's very annoying to try to use a 168 tooth flywheel.
Wait, sorry, you said flexplate. That might be a different ballgame.
Old Nov 19, 2008 | 04:09 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I have a buddy with a starter from a 93 Yukon. I'm going to size that up to see how it fits.
Old Nov 19, 2008 | 05:59 PM
cc 82Z-28's Avatar
Car: 82 Z-28
Engine: Built 406ci
Transmission: 700R4 w/3000 stall
Axle/Gears: 3.73 Torsen Posi, Moser Axles
The mini starter I used to have was a straight dual bolt pattern for either a 153 or 168 tooth flexplate. You don't need another set of holes in your block, just a starter with both bolt patterns. I use a 168 tooth flexplate on my 82 Z with a 400 small block and I had to get a mini staggered bolt pattern starter to work on the 400, but yes a 168 tooth will fit. Hope this helps.
Old Nov 19, 2008 | 08:54 PM
jjlabinski's Avatar
Car: 84 firebird T/A
Engine: shinny 350
Transmission: slush box L65
Axle/Gears: Torsen "3.73"
Watch your header clearance to the starter if you go 168. A lot of headers dont clear the starter when it is moved outwards to accomodate the 168 plate.
Old Nov 20, 2008 | 05:26 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
The mini that I currently have on there will not line up. It wouldn't line up on one of my other birds either. It wouldn't retract until the engine spun it into retraction.
I now have the Yukon starter (free). I'll be trial fitting it this weekend.
Old Nov 29, 2008 | 02:41 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
It's a wonderful life. A Yukon starter fits just fine. It even works.
NORTz89
May 20, 2020 03:51 PM
Steven 86IROC-Z
Car Audio
16
Sep 7, 2015 08:05 AM
nuggie
Aug 25, 2015 01:27 PM
stalkier
Aug 21, 2015 01:54 AM
Fronzizzle
Aug 17, 2015 02:52 PM
