i need education
Old Nov 22, 2008 | 06:19 PM
jstringer50's Avatar
Car: 1989 Camaro
Engine: building a 350
Transmission: TH350
Axle/Gears: soon to be 4.10 non posi
i need education
whats up everyone,
so I posted a few days ago about breaking my speedometer needle, today i bought a parts car, the only difference is mine is an 89, parts car is a year or two older (the owner didnt know the year, I dont know camaros enough to tell)and the speedo has an 85 mph face, which i want to exchange for my original.heres my questionnce the speedo assembly is removed, how do I seperate the needle from the assembly so I can remove the face?
Old Nov 22, 2008 | 06:42 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: i need education
I don't full understand. Why do you wish swap faces (and trying to remove the needle will more than likely break it--they are after all 20+ years old)? You can't swap faces, by the way, and have the speedo read correctly unless they are the same: 85, 110, or 140.
JamesC
Old Nov 22, 2008 | 08:24 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
yea just replace the whole speedometer, each gauge comes out in a section. Swapping needles will just end up with you throwing something or breaking something.
Be sure you got the 85, 110, or 140 like James said.
Old Nov 23, 2008 | 06:30 PM
Car: 1989 Camaro
Transmission: TH350
the reason behind wanting to swap faces is that the car had a 140mph face(i know, its not the right one for my v6 anyways) but I want it in the car regardless for later on when I swap motors. the one I have off the parts car is an 85 mph, which I dont want. I understand its not accurate and I probably have the wrong speedometer in there anyways, thats not the point-i just want to know how to seperate the needle. how do you do white face gauge kits without removing needles?
Old Nov 23, 2008 | 08:13 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
two small flat head screwdrivers, use one as a wedge and the other as a lever, odds are the 20 year old plastic wont hold out.
Old Nov 23, 2008 | 08:14 PM
JamesC's Avatar
I've heard that the needle can be pried off with a fork. The chance of breaking the 20+ year old plastic needle, however, and/or damaging the metal piece that is attached to is 50/50. Proceed at your own peril. Good luck.
JamesC
91REDZ28VERT
Fabrication
Sep 3, 2015 02:28 AM
ChaseDale3and8
Mid-West Region
Aug 25, 2015 06:34 PM
jRaskell
Theoretical and Street Racing
Oct 2, 2002 09:12 PM
StockBastard
Apr 6, 2002 09:22 PM
gruveb
Oct 18, 2001 05:04 PM
