terrible vibrations
Old Dec 8, 2008 | 06:07 PM
perpetualjoshie's Avatar
Car: 86' Z28
Engine: 5.0l w/ new cam
Transmission: TH-350
Axle/Gears: 4.10's
terrible vibrations
ok, yesterday after sitting in a parking lot i turned on my car and it started running very rough. it feels like it wants to bog of the line, theres a loss of power, feels like its miss firing, lower idle speed, and a very bad kinda lumpy jerk when i step on the gas even just a little bit. im thinking it migh be a bad o2 sensor or a clogged fuel filter. the car is a 86 z28 with a 305 tpi. any help would be greatly appreciated.
-Josh
Old Dec 8, 2008 | 06:19 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: terrible vibrations
o2 sensnor should pop the check engine light. Fuel filter can do wonders.
Old Dec 13, 2008 | 02:59 PM
Car: 86' Z28
Axle/Gears: 4.10's
could it possibly be a bad distributer?
Old Dec 13, 2008 | 08:50 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
that, bad plugs, wires.
Old Dec 14, 2008 | 12:21 AM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
-Josh
Check your vacuum to see if the gauge is bouncing all over the place. If it is, then rev the car to see if your car seems to smooth out at higher RPM's. If it does, pull your valve covers and look at your valve springs. Heck, it's fairly easy just to pull your valve covers and look. Might be the easiest and cheapest thing to check first anyway.
A broken valve spring will exhibit the same symptoms. My engine broke a valve spring a few weeks ago and exhibited every symptom you just mentioned.
Old Dec 14, 2008 | 03:04 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Oz, did it tick alot ? even warm?
Old Dec 14, 2008 | 11:15 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I wouldn't say that it was loud, but yes, it did tick. Noticeable at idle, not so much at speed.
Old Dec 14, 2008 | 11:18 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
to me that just sounds a lot like a bad vacuum leak. does your cruise control work? Breaks feel normal? Check your PCV?
Old Dec 15, 2008 | 07:24 AM
Ozz1967's Avatar
Car: 1984 Trans Am
The reason I wanted him to check his vacuum was because if a valve spring is broke, it'll throw off the valve timing in whatever piston it's affecting causing a massive vacuum issues. In mine, the gauge, even at higher RPM, never steadied out...it was always all over the place continually bouncing.
Old Dec 25, 2008 | 08:58 PM
Car: 86' Z28
Axle/Gears: 4.10's
sorry if this is a noob question but, how would i go aabout checking my vacuum? also there is quite a noticalbe tick at idle.
Old Dec 25, 2008 | 10:24 PM
Ozz1967's Avatar
Car: 1984 Trans Am
the tick could be your exhaust manifold leaking. Loosen and retighten all of those bolts.
TO check your vacuum you need a vacuum gauge. Then pull one of your vacuume lines from your carb/TBI/TPI, connect the gauge to the hose you pulled off, plug the other side and read what the vacuum number is. If it's bouncing everywhere, you've got a leak. If it's really low, you've probably got a leak. then rev the engine, if it's still bouncing everywhere, my guess would be that you have a valve problem.
Old Jan 2, 2009 | 07:36 PM
Car: 86' Z28
Axle/Gears: 4.10's
checked the vacuum to and its holding steady at 15 hg. ill try changing the fuel filter tomarro and see if that makes a difference.
Old Jan 2, 2009 | 08:23 PM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Might check for inside of the Dist. cap being wet.
Old Jan 2, 2009 | 08:43 PM
Car: 86' Z28
Axle/Gears: 4.10's
ok ill check for that. what would it mean if it were to be wet?
Old Jan 2, 2009 | 08:50 PM
Moisture (water) had gotten into the cap. That would cause it to misfire and run bad, possible make noise. Have you washed the engine or been driving in the rain?
Old Jan 2, 2009 | 09:13 PM
Car: 86' Z28
Axle/Gears: 4.10's
i have driven in the rain but not very recently, i suppose melted snow could have cause the moisture.
Old Jan 2, 2009 | 09:22 PM
Yes, just pull the cap off and check for moisture.
Old Jan 3, 2009 | 07:27 PM
Car: 86' Z28
Axle/Gears: 4.10's
fuel filter = problem solved.
couldnt have done it without tgo, thank you
InfernalVortex
Apr 20, 2021 11:31 AM
BrianI
Oct 3, 2015 12:57 PM
Eric-86sc
Sep 28, 2015 11:37 AM
mfp189
Sep 27, 2015 09:25 AM
roysatikas
Sep 22, 2015 08:15 PM
