HELP CAR IS AGGRIVATING ME!!!HELP PLEASEEEE
Old Dec 8, 2008 | 07:28 PM
Dany89's Avatar
MY GTA WAS RUNNING PEFECTLY FINE. THEN MY CATALYTIC STARTED TO RATTLE IT SEMS AS IF THE INSIDE IS BROKEN. I KEEPT ON DRIVING IT LIKE THAT AND TODAY WHNE I WNET FOR A RIDE IT TURND OF ON WHILE I WAS DRIVING. I TURNED BACK ON BUT EVERY TIME I LET THE GAS GO THE CAR REVS WENT ALL THE WAY DOWN AND THE CAR TURNED OFF. I HAD TO DRIVE MY CAR WITH THE ONE FOOT ON THE BRAKE AND THE OTHER ON THE GAS. WHEN I GOT HOME I REVED THE CAR AND IT ONLY WENT UP TO 3500/3800 BUT NO MORE THAN THAT. CAR DOES TURN ON WITH NO PROBLEM BUT SOME TIME WHEN I SHIFT GEARS OR EVEN IN PARKING THE REVS FALL AND CAR TURNS OFF!!!
IS THE CATALYTIC TEH PROBLEM OR PART OF THE PROBLEM??? HELP!!!!
MIGHT THE IGNITION COIL BE THE PROBLEM???
Old Dec 8, 2008 | 08:12 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: HELP CAR IS AGGRIVATING ME!!!HELP PLEASEEEE
Is your caps lock broken? Might want to turn that off next time, its the equivalent of yelling at the people trying to help you.
Now if your cat is making a rattling sound chances are thats the problem. Is it original? What kind of exhaust system do you have? A clogged cat will give you problems similar to what your saying, however, cats usually just hollow themselves out, or at least in my experience, but its most likely yours has become clogged. Did you experience any other problems after you started hearing the rattling? Did you have any type of surging in your idle the past few weeks? Could be the TPS and IAC.
Old Dec 8, 2008 | 11:58 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Ok first give us some information as to what condition your car is in. How many miles are on the car? Is the ign system & fuel system stock? If not, then what has been replaced? I am having similar problems (https://www.thirdgen.org/forums/tech...ssing-wot.html). I will update my post after I replace my Ign module tomorrow. -Russ
Old Dec 9, 2008 | 12:47 AM
Dany89's Avatar
Opps sorry for the caps lock
Not really before the catalyic rattled i still drove tha car and nothing happend it was just today that i drove it for about 10mins and will i was on the gas i let go and the car just turned off. i did turn back on with no problmes but i had to keep my foot on the gas otherwise it will turn back off. a littel while ago when i got back home after it coold down i turned it back on and it stayed on with out me having to have my foot on the gas, i left it on Parking and accelerated it but the revs only went up to 3500/3800. i took it for a ride around my street and teh car felt "heavy" when i steped on the gas it didn't respond taht well even if i put my foot all teh way down on the gas teh car felt as if it were being pulled back.
which are the TPS and the IAC???
i dont have the miles of the car right now ill check in the moring but my fuel and ignition system are stock.
Old Dec 9, 2008 | 09:30 AM
Engine: 5.0 TBI
TPS = Throttle Position Sensor
IAC = Intake Air Controller ( don't quote me on this one, cant really remember what it stands for)
kcb37's Avatar
You need a new cat anyway, put on one.
Old Dec 9, 2008 | 09:40 AM
Timothayyy's Avatar
Car: 1992 Firebird
Engine: 350TBI
Axle/Gears: Ford 9in 4.10
IAC is Idle Air controller, I think
Old Dec 9, 2008 | 09:55 AM
Engine: 5.0 TBI
That would be correct. I knew it was something like that ( haven't really woke up yet ).
Old Dec 9, 2008 | 10:21 AM
BluFBdy's Avatar
Car: 89 Camaro RS
Engine: 355 SD TPI
Transmission: WCT5
is it dying from a lack of gas? from the sound of it its bogging down, check the TPS (throttle postitioning sensor) then clean and reset the IAC
Check your fuel pressure, check your filter, etc from the sounds of it there is a lack of gas to the motor
id suggest trying a new map sensor if the above doesnt work out i had a similar issue, when you hit the gas it wil hesitate, bog, then die, and you have to keep it alive at a stop with the pedal. If your gettin the proper fuel pressure then you can just cross the pump, lines, FPR, and filter off the list cuz the issue will be in the system, after the ruel rail, oh check your injectors as well
hope this helps
Old Dec 11, 2008 | 12:20 AM
Dany89's Avatar
How do u reste the IAC???
The TPS and AIC are preatty expensive if i clean them with a cleaner like the ones they sell at autozone will it work???
How would i reset the IAC???
Will cleaning the TPS and AIC with some kind of cleaners they sell at Kragen/Autozone work???
Old Dec 11, 2008 | 12:18 PM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
The tech article on adjusting the IAC is here:
https://www.thirdgen.org/tpimod2
If you want to check and see if your cat is plugged you can unhook the cat. Just let it dangle. Start it up and see if you can rev higher.
Slick89RS's Avatar
Car: 89 Camaro RS
Engine: TURBO 94 LT1
Transmission: T-56 6 Speed
Axle/Gears: 10 bolt 4.10
Here's a quick idea, If you cat was rattling then broke up and plugged the exhaust, remove an oxygen sensor to see if it gains power.
Basically you would be making a hole in front of the converter for exhaust to escape.
If you gain power again, replace the converter and make sure the rest of the exhaust is clear of restrictions ( broken converter pieces )
Old Dec 17, 2008 | 02:44 AM
Dany89's Avatar
I
I took out the converter and reset the IAC. the car does Rev now but every time i put it in Drive i have to keep my foot on the gas. i can drive it around but if i get to a stop and i let go of the gas the car turns off . i dont know whats going on with my GTA :@
I took out the converter and reset the IAC. the car does Rev now but every time i put it in Drive i have to keep my foot on the gas . i can drive it around but if i get to a stop and i let go of the gas the car turns off . i dont know whats going on with my GTA
Old Dec 17, 2008 | 02:57 AM
Saculia's Avatar
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
Did you reset your computer after adjusting the IAC? I suspect that your only problem was the cat. A clogged cat will shut down your engine. Always change one thing at a time when you are not sure of what's going on. You knew your cat was bad to begin with, so change that first and see if things improve.
With your IAC connector unplugged and the computer in diagnostic mode, your car should idle at 450 RPM. After you set the IAC, check the TPS voltage.
Old Dec 17, 2008 | 03:59 PM
Dany89's Avatar
to reste the computer i just disconect the -batt terminal right???
Old Dec 17, 2008 | 04:22 PM
Saculia's Avatar
Engine: 305TPI
Disconnect the negative battery terminal for about 10 minutes.
Old Dec 17, 2008 | 04:25 PM
Dany89's Avatar
i will do that right now
Frozer!!!
Jan 19, 2024 04:55 PM
Reddeath210
Oct 6, 2015 08:20 AM
Linson
Aug 21, 2015 02:12 PM
kyleb24
Aug 15, 2015 08:24 AM
bryan623
Aug 10, 2015 11:33 AM
