Should i Swap TBI for Carb?
Old Dec 23, 2008 | 09:48 PM
CLCAMARO305's Avatar
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
i have a 1990 camaro rs 305 TBI and its not running right i think it has alot to do with either a sensor or the fuel injectors in the throttle body my buddy has an intake manifold and a 4 barrel carb off his camaro 350 motor...should i take his intake and carb and swap out my tbi???
Old Dec 23, 2008 | 10:05 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
Re: Should i Swap TBI for Carb?
message dctrumpet. He has everything for the TBI, do the ultimate tbi mods and ultimate tbi mods 2, get the pieces from him for a real deal.
here is his thread, enjoy.
https://www.thirdgen.org/forums/tbi/502525-custom-tbi-overhaul-kits.html#post3964697
Old Dec 23, 2008 | 10:08 PM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
nah im not wanting to rebuild anything i can get the intake manifold and a carb for free so is a 4 barrel carb and a 350 intake manifold better then a stock 305 TBI
Old Dec 23, 2008 | 10:15 PM
S00828822's Avatar
Car: 1984 Z-28 and 1989 GTA Trans Am
If you can ... stick with the fuel injection. Fuel injection is much better than carburation. Faster starts in hot or cold climate, better fuel economy, better response. I suggest you figure out what the problem is and keep running your tbi. It s much beter than a carb.
Old Dec 23, 2008 | 10:18 PM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
all righty then i think i have a mass air flow sensor that has gone bad that the only thing i can think of its bogging when i put it in the floor and its lacking alot of hp that you can feel should be there....and ive already adjusted the timing, replaced the 02 sensors, and replaced the throttle posistioning sensor
Old Dec 23, 2008 | 10:45 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
seems like you are investing time and money into your car which i love to see. Think about what i said thou, the mods plus the TBI is pretty simple to rebuild, you could have a new TBI unit basicaly in a few hours of work and a little bit of cash, plus the link i gave you, the guy makes all this stuff for our car as a hobby, it's his way of giving back to TGO. He won't charge you an arm/leg like your local parts store for the gaskets, o rings and such.
If you put that carb/manifold on your car you will have to invest some time and money anyways to do the swap.
Old Dec 24, 2008 | 12:01 AM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
ok quick question i wanna swap my intake manifold for his intake manifold he has a camaro with a 350/carb and i wanna put his intake manifold on my 305 and keep my TBI will it fit?
Old Dec 24, 2008 | 12:40 AM
bigbird89's Avatar
Car: 86 Firebird
It won't fit without an adapter. I've had a tbi car, and I recently swapped a cc carb for a non cc carb, which is basically just like converting from tbi to carb. I recommend you stay fuel injected unless there is a major reason to change. It's less work, and you get equal prformance with better gas mileage and cold starts, etc.
Plus, you're emissions legal, in case that ever comes up. Good luck with your project!
Old Dec 24, 2008 | 12:54 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
get the casting number off the intake manifold, then we can help further.
Old Dec 24, 2008 | 06:34 AM
rallysport383's Avatar
Car: 1989 camaro rs
Engine: 383 stroker
Transmission: t5
Axle/Gears: 4th gen/3.55
ditch the tbi and get a carb!
Old Dec 24, 2008 | 07:25 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Hoew about exhaust restriction like a cat going bad.
Old Dec 24, 2008 | 08:26 AM
dctrumpet's Avatar
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Rough.... Thanks for the referral!
Old Dec 24, 2008 | 02:29 PM
afida15's Avatar
also that intake wont fit those heads being that there 1990 heads and that intake your friend has prolly is for 86 and older heads so find that out to. good luck
Old Dec 24, 2008 | 06:02 PM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
good news!!! buddy is getting a new motor YAY!!! i get a free 350 motor =)
Old Dec 24, 2008 | 06:57 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Nice, any pics, casting numbers ?
Old Dec 24, 2008 | 08:17 PM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
nevermind lol he decided not to get the motor so im back to the 305
Old Dec 26, 2008 | 03:30 PM
blp226's Avatar
If you gotta pickapart near you then you can get a good 350 for a couple hundren bucks, If your gonna stick with the 305 then I personally would change the TBI. They'r complicated and a pain to diagnose problems. It's true you will lose gas mileage, but they are so much easier to live with. And problems are much easier to figure out. Thats my two cents, but I admit I know little about ECMs and fuel injection, so carbs are much easier for me.
Old Dec 26, 2008 | 04:20 PM
robertfrank's Avatar
Car: 1988 camaro "SS"/ 1991 305/T5
Engine: 383 LT1 in progress/LT1TBI 355 soon
Transmission: Probuilt 700R4 3600 stall/ T5
Axle/Gears: Moser axles, 3.42 Eaton Posi
I have to completely disagree with this one. IMO diagnosing issues with tbi is very easy to find provided that you have atleast alittle knowledge of the system. You only have nine sensors to really work with (MAT,MAP,IAC,TPS,O2,EGR,KNOCK,CTS,IGN MOD) plus this site is a godsend for help. If something happens to a carb it can be a bitch to diag due to the many mechnical parts in the carb itself that can fail. You wouldn't catch me dead owning another carbed car after having my TBI. This is my opinion.
So getting to the situation at hand, you say your car is bogging down? Have you done a tune up? I would try alittle seafoam to see if it clears anything up. Do that before a tune up if you haven't already.
Old Dec 27, 2008 | 12:05 AM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
i heard seafoam is really bad for older cars, and i think i have found my problem had my bud look at it and we found that one of my injectors is a POS....lol which i told my mechanic this before i replaced anything and $200 later and no injector and im still bogging...so looks like i am a better mechanic but im getting a new throttle body of a junk camaro thats in my buds shop for $20 and everything works sooo we will see how that goes but for now i have to replace the starter should be fun!
Old Dec 29, 2008 | 01:17 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
You get your TBI unit from your bud ? If you don't I have 2 extra 305 injectors here from my last TBI rebuild i wouldn't mind sending you.
Old Dec 29, 2008 | 02:21 PM
Seafoam will be fine for your car. it won't hurt a thing.
Old Dec 29, 2008 | 02:55 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Did seafoam on mine a week ago, nice improvement in MPG, throttle response, cleaner engine, and a smoother idle, not bad for 20$ "2 cans"
Old Dec 29, 2008 | 07:38 PM
chevy89camaro's Avatar
[quote=S00828822;3985551]If you can ... stick with the fuel injection. Fuel injection is much better than carburation. Faster starts in hot or cold climate, better fuel economy, better response.
Not true. i took the throttle body injection out of my car and installed a carb setup. the car use to turn over a couple times before it would fire. with the carb i pump it 3 times cold, then once hot and with a 1/4 rotation or less the engine fires. Not throttle body injected engine has ever done that for me. since changing my car has more *****...89 camaro rs
Old Dec 29, 2008 | 08:12 PM
Car: 1990 Camaro Rs
Engine: 350 Carb
Axle/Gears: shetty
just went and bought a can of seafoam...the guy said to use a half a can per full tank so i put half a can in and im going to see how it helps and waste this gas and put the rest in hope it helps i dont wanna buy a new injector
Old Dec 29, 2008 | 09:08 PM
9tr3g's Avatar
Seafoam made a big difference in my car. You should put some straight in the throttle body slowly. It cleared allot out for me. Have someone in the car to keep it running while you pour it in. Dont let the exaust smoke scare you that means its working
MustangBeater20
Oct 29, 2022 09:20 PM
xkingcodex
Feb 12, 2020 07:43 PM
pimp2303
Jul 27, 2017 02:03 PM
midge54
Jan 29, 2017 07:00 PM
theurge
Aug 21, 2015 12:46 PM
