Engine noise! smog/air pump?
Old Jan 4, 2009 | 01:52 PM
bungo78's Avatar
Car: 88' TA Digital Dash
Axle/Gears: 3:23 Posi Disk 10 Bolt
when the rpm's goes up, or when i drive i get a cranking noise from the engine. when it idles at 5 rpm at a stop or light it goes away. i was told it's from the smog/ air pump. and that camaro's are common for this. What do you have?
Old Jan 4, 2009 | 10:06 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Engine noise! smog/air pump?
Remove the serpentine belt temporarily and see if the noise goes away.
While the belt is off, spin the air pump by hand and see if its making noise. I just had to replace mine due to a noise, turned out to be a failed bearing. It cost me $100 for a new rebuilt one from the auto parts store. It sucks, but its required by law to be there.
Old Jan 4, 2009 | 10:58 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
when i had my air pump off my car i ended up turning it by hand and it made that squeekying noise. so i thought i needed a new one. after i got the new one, i noticed it had a sticker on it that said "it is normal for this pump to make noise if turned by hand". and sure enough it did, made the exact same noise as my old pump. so i went ahead and used my old one and returned the new one. pump doesn't make noise while the car is running. aparently the pump is supposed to make noise if ran under a certain rpm 500? or so. just something to think about.
Old Jan 5, 2009 | 01:23 AM
bungo78's Avatar
Thanks! The noise comes from the front passenger side of engine bay. it has an air suction noise and a tick sound. when i rev up the engine it increases in sound. is this still the same problem?
Old Jan 5, 2009 | 07:58 AM
QuickStyle's Avatar
Car: 91 Z28
could be, like kevin suggested, remove the serpentine belt and run the engine to see if it still makes the noise, don't run it for over 30 seconds though, water pump not running = bad.
Old Jan 5, 2009 | 08:32 AM
OldCelica's Avatar
Car: '91 Camaro 305V8, '91 Camaro 3.1V6
Go ahead and check all of your pulleys. Sometimes it can sound like it is coming from one area when it is actually coming from another. Specifically check the water pump, alternator, and tensioner pulley. My bet is on the alternator.
Old Aug 26, 2009 | 08:08 PM
Caveman305's Avatar
Car: '89 RS, '89 Iroc
Engine: L03, LB9
Transmission: 700r4, T5
Axle/Gears: 2.73, 3.08
nah its the smog pump for sure, same exact noise mine makes, its a bad bearing i still havent changed mine but they only cost 55 bucks here
Old Aug 29, 2009 | 02:09 AM
Bmv5's Avatar
Car: 1986 Iroc-z Camaro
Transmission: 700r4 Automatic
Yep mine does the same, although just tonight my air pump locked up on me. Ugh the smell of burning/melting belt, sound of squealing, and smoke coming up from under my hood scared the hell out of me lol.
theshackle
Sep 17, 2020 08:26 AM
theshackle
Mar 5, 2017 06:37 PM
B_Dubya
Aug 26, 2015 05:09 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
BlackBoulder
Aug 11, 2015 11:15 PM
