good idea or no?
Old Jan 13, 2009 | 09:02 AM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
good idea or no?
i am looking at swapping my entire TPI setup for this:
http://www.sdpc2000.com/catalog/crat...JetEngine.aspx
but it comes with iron heads and low ish compression.
would these heads be ok? or would it raise compression too much
http://store.summitracing.com/partde...5&autoview=sku
or is this a bad idea altogether?
thats all
thanks
oh, the heads are listed as vortec heads on jegs, but i figured you would like summits more complete info so i listed their website.
same price so...
Old Jan 13, 2009 | 05:28 PM
hotrod7687's Avatar
Car: '91 Camaro, 90 Formula
Engine: 355 carb, 305 TPI
Transmission: TH 350, 700R4
Re: good idea or no?
The heads on the engine are 64cc, the summit heads are 62cc. They would probably raise your compression about .2 to .3. Just for the sake of raising compression it wouldnt be worth it.
I believe the fast burn heads do flow a little better than the iron vortecs, but if you're going from a 230HP TPI to a 350HP/400TQ ram jet that would probably be more than enough to put a simle on your face just the way it is.
Old Jan 13, 2009 | 09:08 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
i wouldnt be doing the head swap simply for the compression bump, although that would be a bonus.
i am considering it for the lighter weight, compression, possible power bump ect.
also, the engine that would come out has more than the 230hp.
i would guess around 275-300rwhp isnt unreasonable.
i have no idea whats in it though, so i cant say for sure.
Old Jan 13, 2009 | 09:20 PM
hotrod7687's Avatar
What all have you done to that TPI? If its pushing 300 to the rear wheels, then its making more at the crank than that ram jet.
Old Jan 13, 2009 | 09:45 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
I have no idea what is in the motor. Being that this is the most powerful car I've driven I cantt say how much power it has. I'd guess mid six second 0-60 though
Old Jan 13, 2009 | 10:01 PM
hotrod7687's Avatar
If there hasnt been a head/cam swap then i can almost promise you that youre nowhere near those kind of HP numbers. With bolt-on's like full exhaust, cold air intake, adjustable fuel pressure regulator, ignition mods, etc you would probably be somewhere in the neighborhood of 260-275 HP at the crank.
The TPI can be confusing because it makes so much torque in the lower RPM band, but power takes a sharp fall about 4500-5000 RPM. It pulls like a mother off the line but cant keep it up very long.
If you decide on that motor, I wouldnt go buying any extra heads just yet.
Old Jan 19, 2009 | 11:59 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
well i have no idea what i have.
the original 305 was thrown away as far as i know.
the block is from a pickup
the heads are "chevy stage 2 heads", whatever that means
cam... who knows.
anyway...
Old Jan 20, 2009 | 12:23 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
A better choice than the Ram Jet: http://www.sdpc2000.com/product/SD36...ripEngine.aspx
62cc aluminum heads represents an effective compression loss vs. 64cc iron heads. More heat loss. Might make up for it with better flow, but you'd better have done a lot to the TPI to realize it.
Old Jan 20, 2009 | 09:19 AM
Car: 85 Camaro IROC
Engine: 5.7 TPI
what ECM chip would i use with that?
ecm tuning is the main issue i have right now.
CarGuyDennis
137
Dec 6, 2016 11:02 PM
mdtoren
Aug 23, 2015 12:52 PM
Cripley
Aug 17, 2015 03:35 PM
BurlyChev
Aug 16, 2015 09:08 PM
mdtoren
Aug 16, 2015 05:45 PM
