wild cam...
Old Jan 31, 2009 | 12:21 PM
Exrider434's Avatar
Car: 1988 Camaro
Engine: 383 stroker ported and polished
Transmission: Turbo 400
Axle/Gears: 3.73 Posi
wild cam...
Are they a flat out race cam or will they perform on the street as well?
Old Jan 31, 2009 | 03:49 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: wild cam...
I'm guessing this was supposed to be a reply to another thread, and not a "start a new thread" post?
Old Jan 31, 2009 | 11:09 PM
Exrider434's Avatar
Car: 1988 Camaro
Re: wild cam...
No I was asking a question. I'm new to the whole car thing. The most I know about the cam is tht it's a "wild" cam. Not sure of what that mweans other than I'm pretty sure it was meant to be a race cam.
Old Jan 31, 2009 | 11:22 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Re: wild cam...
Depends on the definition of "wild."
Old Jan 31, 2009 | 11:59 PM
Exrider434's Avatar
Car: 1988 Camaro
Re: wild cam...
I don't know, that's kinda the reason I'm asking. It's supposed to go in a 383 stroker if that helps any?
Old Feb 1, 2009 | 12:02 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Re: wild cam...
You match the cam specs to the engine package and desired performance. There really isn't a rule that says "x" cam is meant for "x" purpose. Generally speaking, though, larger durations are typically meant for more of the racing/high end application (240°+ @ .050" intake duration).
Hot street applications, like 383's or 400's can typically handle a larger cam, in the 232ish @ .050" and still be streetable. Again, though, that's more or less general application.
thekurlyone
Sep 30, 2015 12:54 PM
Marc Brown
Sep 28, 2015 01:40 PM
pacoelrapido
Sep 11, 2015 02:41 PM
Nomar116
Oct 26, 2001 11:19 PM
fb305svs
Oct 5, 2000 10:31 AM
