Any 305 Roller Factory
Car: 92 Camaro RS
Axle/Gears: stock
Did any 90 to 92 305 camaro's come with a roller setup from factory?
Besides the corvette. Thanks to ALL.
Car: 92 Camaro RS
Axle/Gears: stock
Re: Any 305 Roller Factory
So I have a 1992 RS 305, are you saying ALL 305 & 350 are Roller?
How can I tell if mine is a Roller motor?
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
idk i got a 350 and it was a flat tappet best way is to open it up and pull a lifter. thats what i did.
Transmission: 4L80E/4L80E
From the factory, all U.S. passenger cars 305 & 350, '88-up, got roller lifters.
If you saw something that fits that description that had flat tappet, either the cam or engine has been replaced.
Car: 92 Camaro RS
Axle/Gears: stock
Well that could be the case, I dont know this car, bought for the TPI.
Then the motor could be a 350, how to tell this by lookN at it?
Car: 1991 Trans Am
Axle/Gears: Stock
its should say 5.7L on the driver side of the block where the tranny connects by the back of the block
Car: 88 Firebird T-Top
Engine: 350 crate
Transmission: 700r4 w/shift kit
Axle/Gears: one's that move the car
i have 2 305 ho rollers one needs to be rebuilt and one is rebuilt..one has e-tech heads and the other has v-tech heads both have 5.0 ho stamped on back of block
Car: 1991 Trans Am
Axle/Gears: Stock
ITs going to have whatever balancer is on it, they are interchangeable. The only way to know what size engine it has is to get the casting number off the block. Same year, same car is probably going to have the same balancer installed.
Car: 1991 Trans Am
Axle/Gears: Stock
if its a stock balancer and its skinny its a 350 if its wider its a 305 but im not gonna argue over this... who would change a balancer and put a 305 one on a 350 or vise versus thats would not make sense but w/e
Car: 92 Camaro RS
Axle/Gears: stock
OK, the 1990 Friebird T/A has the narrower balancer, 5.0 on back of block.
My 1992 Camaro RS has the wide balancer 5.0, why to different balancers?
I guess the difference in the years maybe! It really dont make any since.
Depending on the year and the specific engine, they are not different at all, they will have the exact same part number. I'm glad you wont argue, because you are not right. Why would it not make sense? The balancers are not CI dependant, they are dependant upon the diameter and how it works with the rotating assembly and timing tab.
Car: was 85 TA, 91 TA both sold
Engine: was 406, now 305 tpi
Transmission: 85 had700r4,350..91 had t5
Axle/Gears: 323,373,342
balancer may change between stick/auto
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
FWIW, the 5.0L in my '87 IROC has a factory roller cam.
What's also strange is that it has center bolt valve covers, but it doesn't have self-aligning rocker arms. It also has the lo-po rotators on top of the exhaust springs.
Car: 1991 Trans Am
Axle/Gears: Stock
Car: 1991 Trans Am
Axle/Gears: Stock
oh alright sure but w/e some motors you can tell like!!!! that can you not?
Car: 92 Camaro RS
Axle/Gears: stock
Well all I can say is that the balancer is diff. from 1990 Firebird to a 1992 camaro.
Both are 305 CID both are a AUTO. and they are both center bolt valve covers.
So you STILL have not said why the bal. is DIFF. Thanks.
No, you cant. The press fit size of the balancer is the same between the 305and 350. They will in fact use the exact same crankshaft casting, just a different balance. The balancer can differ depending on pulley/belt configuration, timing cover/tab configuration (Actually the tab changes per the balancer, but its all the same), and possibly the trans combo (although I havent seen proof of this being a deciding point). The only real engine you can tell the difference on is a 400. 305/350 is the same.
Car: 1991 Trans Am
Axle/Gears: Stock
not mine i have a 305 and a 350 and they are different so your wrong...
I can post part numbers if you would like, but what good would that do. Sometimes I wonder where kids learn it all at such an early age nowadays. Take the one off the 305 and put it on the 350, did he 350 just lose 45CI?
I went ahead and got the part numbers. Here is a lookup on a 1988 camaro:
305:
27-305-F 12551537 $157.22
350
27-Vibration Damper 12551537 $157.22
The first part is GM part description in alldatapro catalog. Then part number and price.
Car: 1983 G20 Chevy
Transmission: 4L60
You have NO clue what you are talking about. I have seen 350s and 305s BOTH running either 6 3/4" or 8" diameter balancers out of the factory. Just depends on the year and application. Most of the performance cars ran 6 3/4" balancers and trucks typically have the 8" balancer. As long as you have the timing cover to match it is 100% interchangeable between engines as even the FACTORY did it!
Car: 1991 Trans Am
Axle/Gears: Stock
man STFU i was told i was wrong cant you read above so uhhh yeah so keep on talking that
im done at this post... Thread
junkcltr
Aug 2, 2019 11:12 PM
ambainb
Apr 25, 2016 09:21 PM
MoJoe
Sep 24, 2015 09:12 PM
