quick advice on dead car PLEASE
Old Feb 17, 2009 | 07:53 PM
redliterunner's Avatar
Car: 89 IROC convert.
Engine: tpi 305
Axle/Gears: 3.42 10 bolt
Well, I was bitchin about my car this morning and it got even this afternoon.
Out of nowhere it started running rough at a stop light, then died. Restarted for about a second, sputtered and died, same thing about 5 times.
Towed it home and now it's got nothing. Turns over normal...but no start.
Any ideas?
Thought I might have been out of gas, because it was lower than I usually let it get, but I put a gallon in and still no start.
I'd like to get it back on it's feet tonight so I'm accepting all wild *** guesses.
I'm thinking maybe ignition module.
Thanks in advance.
Old Feb 17, 2009 | 07:59 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: quick advice on dead car PLEASE
Ok first check your fuel pressure. I had similar problems and it was due to 21 years on the original pump.
Old Feb 17, 2009 | 08:05 PM
Engine: tpi 305
I'll try that first, but I'm still open to other suggestions.
Old Feb 17, 2009 | 08:10 PM
Engine: tpi 305
Guess what...0 fuel pressure. The pump isn't even running. Is there a fuse or relay I should check first.
Old Feb 17, 2009 | 09:53 PM
pwdbychevy's Avatar
Car: 1991 Camaro Z28
Engine: Dart SHP 406ci T88 turbo
Axle/Gears: QP 35 spline Ford 9" 3.50 gears
There is a fuel pump test port on the rear passenger side of the engine compartment. Apply 12v+ to it and listen for the fuel pump to come on. If it doesn't then probe the fuel pump connector at the rear of the car above the rear axle(on the body) and then have a buddy apply 12v+ to the fuel pump test connector and check for power at the connector. If there is power at the connector then your fuel pump is bad and if not then check the relay.
Old Feb 18, 2009 | 10:16 PM
j'scrossfire83Z's Avatar
Car: 83 Camaro TT-Z-28
Engine: Twin Turbo9psi 383 Stroker CFI
Transmission: Monster 700r4 (26 mpg)
Axle/Gears: 3:73
well enjoy swapping you fuel pump. i had my taste of a red neck victory when i got the fuel pump out of a junk camaro, i cut out the carpet and tin snipped the floor right above the pump. I had it done in 10 minutes. but god has a sense of humor. As i was getting my tools i gashed my arm on the cut metal. Just what i get for molesting a third gen.
Old Feb 18, 2009 | 10:22 PM
Axle/Gears: 3:73
Where did you get the back cover/sunshade for the hatch? It may be factory on the car, or maybe i am just proving my ignorance! lol
Old Feb 18, 2009 | 11:00 PM
pwdbychevy's Avatar
I bought that a LOOOONG time ago from GTS when the car was in Germany.
Old Feb 19, 2009 | 10:42 AM
Engine: tpi 305
Man this fuel pump change SUUUUUUUUUUUUUUCKS! I'm gonna be two evenings, at least, getting it done, and that's without any cleaning or painting of parts, which I usually try to do. The car looks like a bomb went off under the rear. At 50, I'm getting a little old for this.
Old Feb 19, 2009 | 11:48 AM
pwdbychevy's Avatar
Yeah it sucks. When it happened to me I had just filled up the tank. Murphy's Law I guess.
Old Feb 24, 2009 | 12:20 PM
Engine: tpi 305
Well it's all done and I'm glad about that. hope it goes another 150,000 before I have to get into that again.
Old Feb 24, 2009 | 01:01 PM
pwdbychevy's Avatar
Good Job! If only GM would've installed an inline pump instead?
justin57
Aug 20, 2015 07:05 PM
jharrison5
Aug 19, 2015 05:53 PM
hokis
Aug 9, 2015 03:57 PM
L98GTA87
Aug 5, 2015 11:02 PM
