provision for mechanical fuel pump
Old Feb 24, 2009 | 10:05 AM
yevgenievich's Avatar
Car: numerous
Engine: ls1, others
Transmission: t56, others
Axle/Gears: 3.23 7.6"
had a question about putting mechanical fuel pump on 305 TPI out of 89 trans am. Looks like there is a cover plate to where it would go but does the cam has the lobe to drive the pump?
Old Feb 24, 2009 | 01:37 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: provision for mechanical fuel pump
I thought that you couldn't operate a TPI on a mechanical fuel pump for lack of adequate pressure.
Old Feb 24, 2009 | 03:10 PM
Car: numerous
Engine: ls1, others
it's going to be carbed, i was just stating that it's originally a TPI motor
Old Feb 24, 2009 | 09:00 PM
Mrgref92's Avatar
Car: 1986 Camaro Sport Coupe
Engine: L69
Transmission: 700-R4
Axle/Gears: 2.73's
There should be like a 5-7 inch piece of hardened steel that pushes up into the engine, you can keep it up with grease, then slide the pump in and It should work, But this was for a carbed 305, so idk if tpi would be a different pump
Old Feb 24, 2009 | 09:13 PM
squirted1's Avatar
Car: 84 Trans Am
Engine: 383
Transmission: Tremec TKO
Axle/Gears: 10 bolt 3.73 lsd
you should be able to use a mech pump on that block if it has a cover plate. However, I don't remember if the tpi cam has a pump lobe or not
Old Feb 24, 2009 | 09:20 PM
steeljab's Avatar
Car: 87' Camaro
Engine: 305 carbed
i think he was asking if his motor, a 89 305 tpi has the cam lobe to drive the pump.....which i unfortunatly do not know XD
Old Feb 24, 2009 | 10:35 PM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
If your pump in the tank is still working, then all you need is to get a proper regulator for carbs and you are done, Otherwise you will have to get another sender/fuel intake assembly, drop the tank and plumb it up. Is the in-tank pump working? If you get a regulator, make sure it is a "Bypass regulator".
Old Feb 25, 2009 | 09:50 AM
Car: numerous
Engine: ls1, others
motor is temperely going into a different vehicle with carb setup and no electric fuel pump. The block does have the block off plate, so the block can support mechanical pump but i wasn't sure if the original cam would have the lobe to support mechanical pump.
Old Feb 25, 2009 | 12:56 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
NO, TPI roller cam does not have cam lobe.
Buy a basic summit electric in line pump for $150 or whatever it is. They are louder than SIN though.
Recommend looking into an aftermarket, more agressive, roller cam, with fuel pump lobe.
Old Feb 26, 2009 | 03:03 AM
Yes, what he said, especially if it is temporary.
Old Feb 26, 2009 | 05:55 AM
Damon's Avatar
Not sure what year they stopped putting a fuel pump lobe on the factory cams. I have an 87 L98 cam and it definitely DOES have a fuel pump lobe. Got one out of a 92 and it definitely does NOT have a fuel pump lobe.
You're right in the middle, so I'd definitely check for yourself.
RazorN8
Jan 7, 2022 11:44 AM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
gta90
Sep 15, 2015 04:00 PM
justin57
Aug 20, 2015 07:05 PM
