need help- heads will not pry off?
Old Mar 10, 2009 | 08:40 PM
kymission's Avatar
gotta get these dang things off. Does anyone have any suggestions. I am in great need.
thanks
Old Mar 10, 2009 | 08:45 PM
coop427's Avatar
Re: need help- heads will not pry off?
make sure you removed all the bolts and they will pop right off.
Old Mar 10, 2009 | 08:55 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
17 bolts per head, then pry up from the intake side of the head. Wrap a rag around a prybar and put it into one of the intake ports.
Old Mar 10, 2009 | 10:03 PM
kymission's Avatar
well I have removed 8 bolts on the outside of each head, and 9 bolts on the inside of the head. I have not been able to pry them off. I have search for more bolts to no avail. I have beat the hell out of it with a rubber mallet. Next I am about to try a real hammer. I am so frustrated. They will not simply pry off.
Any other ideas?
Old Mar 10, 2009 | 10:04 PM
kymission's Avatar
well I have removed 8 bolts on the outside of each head, and 9 bolts on the inside of the head. I have not been able to pry them off. I have search for more bolts to no avail. I have smacked the hell out of it with a rubber mallet. Next I am about to try a real hammer. I am so frustrated. They will not simply pry off.
Any other ideas?
Old Mar 10, 2009 | 11:25 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
Where are you prying them from? I usually just put the handle of a breaker bar into an intake port and pry upwards (gently)
-Zander
Old Mar 10, 2009 | 11:49 PM
johnny89345's Avatar
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
tap the head with one of those plastic hammers a few times on the side then try the shock should loosen it up
Old Mar 11, 2009 | 01:04 AM
OldYellr325's Avatar
Car: 86 Camaro
Engine: LG4
I ran into that once during my first rebuild. The heads had been on for about 170k miles. It took a large rounded tip flat head screw driver and a RUBBER mallet. A very dangerous approach but even a prybar crowbar and a 20lbs x 6ft steel bar would not seperate those things. The gasket had baked in there pretty good.
I had to get an old very large flat head screw driver to seperate em. I ground the edges down pretty smooth so there were no corners. That way I didnt run as high a risk to scratching the gasket surface. If you come in from the intake side at the front seal where there is a very tiny overlap from the head to the front oil seal surface of the intake and start tapping GENTLY directly in line with the head gasket it will begin to seperate. Once you have broken the seal use a prybar to finish the job.
I can not stress enough how bad an idea this is but if ALL else fails it works.
Old Mar 11, 2009 | 01:37 AM
birdtojag's Avatar
Car: 87 Firebird, 90 bird coming soon
Engine: 355 Chevy Vortec Heads TPI, LT1 inj
Axle/Gears: 2.77 posi 9-bolt
Did you remove the push rods? If not, do that first. Then do the screwdriver method and you can use the upper corners of the head by the water ports. It's worked for me several times.
Old Mar 11, 2009 | 02:05 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
And.. if that fails, use dynamite. Half a stick should do. Seriously, if all else fails, I agree with these guys. Use a screwdriver.
Old Mar 11, 2009 | 02:17 AM
Car: 1987 iroc z
Engine: 350tpi
Axle/Gears: 342
just know your limits with the screwdriver make that your last resort .even try some spay like pb and let it soak all night you dont want to f**k your heads up
Old Mar 11, 2009 | 07:48 AM
kymission's Avatar
I put pb blaster on last night. I hope this works. I will try later today to pry up again. Wish me luck
Old Mar 11, 2009 | 07:29 PM
Guest
Guest
Posts: n/a
Try not to break off the dowel pins that are at the bottom ends of each head. If you do too much beating on them from the side or tip them too far you could break them off.
I've used the screwdriver method a few times. Put it between the block and head near the water ports and tap away at the gasket and it should break loose.
Old Mar 11, 2009 | 11:01 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
I always stick a pry bar into the exhaust crossover and pull up. Always breaks them free.
norcalz28
Northern California
26
Dec 7, 2016 12:49 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
