Take off sucks! What can i do?
Old Apr 12, 2009 | 06:49 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Hey guys i have a slow car but still want it to take off good! I have a 305 tbi with 3:73s but when i test my 0-60 time or something i gun it and it starts at like 1000rpms and slowly builds its self to about 2 and then its good the rest of the way. I cant even turn the tires over just by stomping on it? I think that will really help my 0-60 time and stuff (best 7.7 sec). I am going to be puting a aluminum driveshaft on soon!
thanks
kevin
Old Apr 12, 2009 | 06:54 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Take off sucks! What can i do?
spinning the tires will not make you faster
Old Apr 12, 2009 | 06:56 PM
I know that im just saying i should be able to but it just kinda bogs in the start.
kevin
Old Apr 12, 2009 | 07:00 PM
the zander's Avatar
Car: 86 Camaro IROC-Z
Engine: 305 TPI (retrofit)
Axle/Gears: Crappy stock 10-bolt gears
how are you launching? ie: Brake stalling, or just mashing the throttle off the line ?
-Z
Old Apr 12, 2009 | 07:03 PM
At first i was power braking it some but it dose better just to stomp on it.
kevin
Old Apr 13, 2009 | 12:52 AM
drknow90rs_ss@y's Avatar
Car: 86 IROC-Z, '71 RS
Engine: 305 TPI/ 350
Transmission: 700R4/TH350
I would change your torque converter. Something like a 2200 rpm stall would be good for a daily driver. Just for comparison, go to your local dragstrip. Most dragstrips have an "Open" night where they let anyone run. (Typically a friday night.) Look at your timeslips for the 60' time. Then change out your torque converter and go again. you should see an improvement on the 60' times. Also you could install a shift kit and corvette servo. My TPI 305 IROC has 3:73 rear gears and a full race-built 700R4 and eats 350 TPI cars. The difference is all in the trans.
Old Apr 13, 2009 | 06:08 AM
I have i high performance shift kit with a corvette servo! Just didnt know if anyone knew anything?
kevin
Old Apr 13, 2009 | 02:53 PM
d2harris's Avatar
Car: 92 Camaro Z28
Engine: 5.7 350 TPI
have you done a tune up lately? Most bogs are caused by spark or gas not getting into the engine. Maybe change your fuel filter
Old Apr 13, 2009 | 03:05 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Remove the boat anchor and install a 350 with a carb and problem sovled. If that dosent float your boat the just throw in a 350 long block and swap all you crappy tbi over.
Old Apr 13, 2009 | 03:07 PM
Iv done a tune up mabey 4k miles ago and never changed the fuel filter iv put about 9k miles on it. the fuel filter isnt rusted or nothing but i do have a new that i could put on.
kevin
Old Apr 14, 2009 | 04:15 PM
anything else?
kevin
Old Apr 14, 2009 | 04:21 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
if it bogs like that out of hole.....put a stall convertor in it...
Old Apr 14, 2009 | 04:25 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
i got a 2200 stall on a highly moddifed 700r4, 3.23, and a 305 TBI and mine will get up and go off the line with no problem, even with suspention modds, i still lose traction off the line...
i would try the fuel filter, something simple ya know, run about 1/4 a gallon of diesel in the tank, that will clean the injectors (or spend $5 for injector cleaner, its the same thing
a higher stall will help, i cant remember how much help i gave me, my car was almost bone stock when i put the 2200 in it, but i know it felt better off the line....im sure i would hate to put a stock stall back on mine
Old Apr 14, 2009 | 05:10 PM
danandamy's Avatar
Car: 86 Camaro
Old Apr 14, 2009 | 07:36 PM
CodyC123's Avatar
Car: 86 Z28
Engine: 385
Transmission: T5 (soon to be in pieces)
Axle/Gears: 3.73 POSI Disc
mine did the same thing, turned out to be a plugged cat. might want to look into that
Old Apr 14, 2009 | 07:41 PM
Well all a/c and emmisons are gone w/ the cat. How much for a 2500 stall and how much to install?
thanks
kevin
Old Apr 14, 2009 | 08:43 PM
89RS_82Z's Avatar
gonna be pricy, go to jegs or summit
a B&M is about 250
Hughes 390
TCI 425
all of them are 2500 stall
install depends on the shop, i would guesstamate 200-300....i dont know i do all my own work, but thats what i would charge i hate pulling/dropping a trans
Old Apr 15, 2009 | 06:08 AM
Is it worth it how much difference should it be?
thanks
kevin
Old Apr 15, 2009 | 08:43 AM
sccavette's Avatar
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
One thing you might want to check is the base timing! If the timing is retarted it will be soft coming out of the hole. This can happen in time with wear on the timing set.
Set the base timing to 8-10 degrees (10 if you are running high octane) and see how much difference that makes. Keep in mind the more initial timing will help the bottem end (low RPM) however it can hurt the upper RPM range so the car may not pull as hard at the higher RPM. You can play around with the setting to see where your car runs the best.
The fuel filter as mentioned earlier should be replaced. Just because it is not rusty on the outside does not indicate it is good. I change the fuel filter around once a year.
Old Apr 15, 2009 | 08:52 AM
Engine: L98 494hp
Check the basics first...then go into buying new parts.....it won't help you to put new stuff on a un-tuned car......if everything is in check.. a 2000 or 2500 stall would probably help.....remember you cam is for low rpm (stock I assume?), so a 2000 rpm stall might work good. some people, including myself before, have gone a cheaper route with the stall convertor.....instead of buying an expensive aftermarket stall convertor, go to your local parts store and get a chevy s10 blazer (votec motor v6) factory torque convertor (get HD version), and put that in your car.....they are very inexpensive and stall up around 2300-2500 rpm....I think they are under $100 new (not for sure). It's like a poor mans stall But you might try that, just a thought.......
Old Apr 15, 2009 | 12:38 PM
Big Dog Chevy's Avatar
Car: A lot and 86' Z28 and 88' Camaro
Engine: 305, 383 and 565
Transmission: 700R4, th400 and 4L80
Axle/Gears: Frd 8.8 /3.27 and S60
You should be able to spin the tires with a stock 305 and 3.73 gears. There is something else wrong. Like the guys said check the basic stuff first. When my lil 305 was stock with a 2.73 gear I could spin the tires with 255/50-16 GFGs on the back. Get it running right first before you start spending money on other parts.
Old Apr 15, 2009 | 01:37 PM
The idel is up high? When start up it might hit 1900 rpms then drop to like 1400 when its cold but when warmed up in drive its around 800? I think i will do the fuel filter real soon!
kevin
Old Apr 15, 2009 | 02:12 PM
sccavette's Avatar
Engine: V8
kevin
I would be looking for a vacuum leak also if the idle is high. Check the shaft in the TB and make sure it is not worn and leaking. If you are daring you can spray some starting fluid around and see if you can find the leak, keep in mind if done incorrect you will start a fire.
How many miles are on the car? Do you know what kind of condition the injectors are in?
Old Apr 15, 2009 | 03:02 PM
Well it has 93,5xx miles. I try to and put in fuel injector cleaner every now and then. But i have no clue how to tell if their good or bad?
kevin
Old Apr 15, 2009 | 04:19 PM
89RS_82Z's Avatar
kevin
start the car, take your breather off, and look at the spray it should look pretty (lack of better words) but a fine spray, no huge dropletts or drips.....if you want to see how a new injector sprays tell me, i got a brand new TBI on mine and could take a video and youtube it for ya
Old Apr 15, 2009 | 04:22 PM
Ok i will do. what dose ur lo3 run in 0-60?
kevin
Old Apr 15, 2009 | 04:39 PM
Ok so i went and looked and first seen that my air filter is ate up!? Whats going on!? Then the fuel was for the most part fine spray but their was bigger drips i tried to take pics. They are not the best and you cant really tell but how much are new ones and could i go bigger?
thanks
kevin
Attached Thumbnails Take off sucks! What can i do?-mvc-001s.jpg   Take off sucks! What can i do?-mvc-002s.jpg   Take off sucks! What can i do?-mvc-003s.jpg
Old Apr 15, 2009 | 04:41 PM
89RS_82Z's Avatar
kevin
i really dont know, its faster than the speedo, for some reason the speedo dont do to well being smooth when you floor it....i do know..before the 3.23, and some of the mods, losing traction lake crazy off the line, and shifting early (4600) i ran a 9.5 in the 1/8.....and that was less than desirable conditons open diff with 2.73, old crappy TBI to
my mods are in my vBGarage, but not all them where on the last time i was at the 1/8
i do know that like i said before, even with suspention moods and a LSD i lose traction off the like and going into 2nd, its not sluggish at anypoint really....you got some issue going on and alot of good ideas of things to check, its one or a combo of a few, but all the ideas people have gave you i highly recomend you do/check
Old Apr 15, 2009 | 05:08 PM
chevyhead420's Avatar
Car: 92 camaro 25th anniversary edition
Engine: 305 Tbi
Transmission: auto
i have a 1992 25th ann edtion wit a 305 tbi and this is what i would do. depending on where you live with emissions hollow the cat out. or buy a new one. get a tbi off a 350 clean the **** outta it with brake clean, spend the extra money and get the good plugs, do the fuel filter and the air filter, check your vaccum lines and you should be able to burn the tires off, this is what i did to mine and they def spin, good luck bro
Old Apr 15, 2009 | 05:18 PM
sccavette's Avatar
Engine: V8
thanks
kevin
Do you have a timing light? If you do hook it up as normal and start the car with the air cleaner lid off. Point the timing light at the injectors and when it flashes you will be able to see the spray pattern of the injectors. It should have a nice even cone shaped spray pattern.
Old Apr 15, 2009 | 05:20 PM
ok ill try that later!
kevin
Pac J
May 17, 2020 10:44 AM
smnichol86
Brakes
26
Mar 26, 2017 10:55 PM
tyeo098
Nov 30, 2015 06:27 PM
wanext
Oct 6, 2015 12:18 AM
3.8TransAM
Oct 1, 2015 07:47 PM
