is there an easy way to change the spark plugs
Old Apr 15, 2009 | 05:33 PM
ghost stripes's Avatar
some are easy to get to and most are impossible ...please tell me there is a easy way
Old Apr 15, 2009 | 06:10 PM
blkfirebird91's Avatar
Car: 1991 Trans Am
Engine: 305tbi to 350 carb'd
Axle/Gears: Stock
Re: is there an easy way to change the spark plugs
go under the car and do it that way i had to for cyl 8
Old Apr 15, 2009 | 06:15 PM
1989IROC-Z5.7L's Avatar
Car: 1987 Buick WE4 Regal
Engine: 3.8L IC Turbo
Transmission: 200 4R Auto O/D
Axle/Gears: 3.42 posi
Let someone else do it ! ! !
It is easier to go under the car to get to the pass side plugs.
Old Apr 15, 2009 | 06:22 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Like said above you REALLY have to go underneath for some. If you switch to headers, they can all be reached from the top. I was excited when i put my plugs in with headers!
Old Apr 15, 2009 | 06:25 PM
Car: 1991 Trans Am
Axle/Gears: Stock
lol me too so much easier with headers
Old Apr 15, 2009 | 06:26 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
yes there is an easy way.
there was a pic on this board that showed a tool made for doing it.
take a plug socket and cut a long piece out of it - just wide enough for the cut to fit over the extended part of the plug.
then its easy.
i did a quick search for the picture but it did not pop up quickly - you need to look for it - it is there. you can buy the took for 45.00 or you can just cut a slice out of one of your plug sockets for free.
found it https://www.thirdgen.org/forums/tech...ark-plugs.html
take a look.
Old Apr 15, 2009 | 06:30 PM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
6 out of 8 I got from under the car.... while your under there do an oil change...
Old Apr 15, 2009 | 07:55 PM
thanks i will try going under the car
eightsixseven
Dec 16, 2024 01:50 PM
apo_bailon15
Mar 28, 2016 05:20 AM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
