Car wont get fuel to injectors
Old Apr 17, 2009 | 01:31 PM
the311godfather's Avatar
I have a 1992 Camaro TBI 305 RS and i'm not getting any fuel to the injectors. I had gas dripping out of them becuase it sat over the winter and when i opened the gas cap it quit dripping so i know it's not injectors that are bad. I was wondering if this sounds like a fuel pump problem. I have power to both injectors but it's like theres no pressure building up to get it to the injectors and spray. Any help would be handy at this moment seeing i havent had a car in roughly 5 months lol.
Old Apr 17, 2009 | 01:39 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Re: Car wont get fuel to injectors
check fuel pump relay, fuse, and change filter...probably fuel pump....try hitting gas tank with rubber mallet while having someone cranking on it...it might free up pump
Old Apr 17, 2009 | 01:56 PM
John 89 Formula's Avatar
Car: 89 FORMULA FIREBIRD, 86 CHEVY CAMARO
Engine: L98, LB9 RESPECTIVLY
Transmission: 700 R4 (BOTH)
Does the fuel pump prime when you turn on the key? You should hear it run for about 2-3 seconds to pressurise the system.
Old Apr 17, 2009 | 01:57 PM
I have changed the filter twice and the pump primes. I will jump on looking at it after i get off of work. Thanks for the suggestions guys
Old Apr 17, 2009 | 02:00 PM
Have your ignition module tested, a bad ign module will prevent the injectors from spraying.
Old Apr 17, 2009 | 02:34 PM
I tapped on the tank and it worked but the car is running but not off the injectors lol. So now i got the car running i have to figure out how to get the injectors to spray.
Old Apr 17, 2009 | 04:38 PM
I'm sorry but this dosen't make any sense, the motor absolutly will not run if the injectors are not spraying. (maybe with a shot of starting fluid, but then only for 4 or 5 seconds)
Old Apr 17, 2009 | 09:57 PM
As weird as it sounds thats how it is running i watched it. i had my dad sit in the car and it is absoultley not spraying from the injectors. I still dont know how it is running like that. When i take my foot of the pedal the throttle closes and it stops running
Old Apr 18, 2009 | 01:40 AM
rgarcia63's Avatar
Car: 88' IROCZ
Engine: 388 TPI Motown 350 Race block
Axle/Gears: 2.77
Running on fumes LOL
You know it won't run without fuel, it is spraying you just can't see it.
Check fuel pressure 10-15 psi anything less is going to cause problems.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
kyleb24
Aug 15, 2015 08:24 AM
