engine stalls in gear
Old Apr 23, 2009 | 08:21 PM
juggalo4life199's Avatar
Car: 1989 camaro rs,2003 suburban z71
Engine: 350,5.3
Hey guys i hope you can help me i just replaced my intake gasket and fuel injectors on my 350 tbi. The car starts up fine like normal idles about 750 rpm but when you go to shift it into reverse or drive and then left off the gas the car stalls out dont know what is causing this any suggestions. have changed the iac and tps. thank you
Old Apr 24, 2009 | 08:46 AM
Engine: 350,5.3
Re: engine stalls in gear
is there any one that can help me please
Old Apr 24, 2009 | 05:59 PM
Engine: 350,5.3
help please
Old Apr 24, 2009 | 08:04 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Automatic or Manual?
I am having a similar problem in my 84 T/A that just got a new motor. My problem only happens when it's cold though.
Old Apr 24, 2009 | 08:28 PM
Engine: 350,5.3
its an automatic it origanally had a 305 in it and a switched it to a 350 and just finally had the money to replace the intake and fuel injectors i think it might be a bad brake booster when i first started it after the swap it ran fine and i relized the hose wasnt hooked up and then thats when it started need to get timing back set right and battery stay charged long enough to check for shure but any other suggestions would be great
Old Apr 26, 2009 | 03:09 AM
Engine: 350,5.3
any one have any other ideas what it could be
Old Apr 26, 2009 | 07:31 AM
vortek's Avatar
Car: '89 RS
Engine: 350 Vortec
Transmission: TCI 700R4
Axle/Gears: 3:73 Eaton
Did you change out the ECM?
Old Apr 26, 2009 | 12:32 PM
Engine: 350,5.3
yes when i got the new motor it had the ecm with it and i switched it when i did the swap
Old Apr 28, 2009 | 01:06 PM
87fbird's Avatar
Car: 1987 Firebird
Engine: L98 350 tpi
can anyone help with this I have the same problem
Old Apr 28, 2009 | 04:05 PM
1990Phoenix's Avatar
did you clean or replace the IACV??
Old Apr 28, 2009 | 07:12 PM
Engine: 350,5.3
yes i cleaned out the tbi unit before ever switching anything and then i also changed the iac
Old Apr 28, 2009 | 07:32 PM
BtownZ28's Avatar
Car: 1984 Z28
Engine: 305 LG4
So it ran normal before the intake and fuel injectors?
Old Apr 28, 2009 | 07:49 PM
Engine: 350,5.3
yes it ran normal you could say just didnt have any power when i put back everything together it ran fine too except i forgot to hook the vacum hose to the brake booster and tried to drive it did fine just breaks hard to press then check and hooked the vacum up to the booster then started doing this
Old May 22, 2009 | 06:59 AM
vortek's Avatar
Car: '89 RS
Engine: 350 Vortec
I just have paid better attention to your thread. I would say the check valve is shot or the filter could be cracked ( the odd ball thing in the line). For under 10 bucks I would replace these first. Let me know
Old May 22, 2009 | 12:06 PM
bilms01's Avatar
Car: 89 Firebird
Engine: 350 Ramjet
Axle/Gears: GM 9 bolt 3:27
The check valve's primary purpose in simply to hold vacuum in the booster for a few assisted brake applications if the booster vacuum source is lost. If there was a problem with the check valve or filter it would be the same as a large vacuum leak or there would be no power assist at any time (engine running or not)
If the engine ran fine after the intake and injector replacement with the booster vacuum hose disconnected That is a large vacuum leak. the motor probably would not idle much less run very well if at all. If it ran "fine" until you connected the booster hose then started having your issues I would suspect a fuel issue. If it can run fine with that large a vacuum leak it is more than likely getting an ungodly amount of fuel. You may want to rethink your choice or question the quality of injectors since the intake and injectors wwere the only things you changed. I would also check the FPR for a leaking diaphram allowing fuel to get sucked into the intake. Simply look at the vacuum hose (FPR) and see if there is fuel in it.
jklein337
Sep 19, 2018 06:23 PM
Wade787b
Sep 29, 2015 01:15 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
mizz0313
Aug 12, 2015 06:45 AM
