4.3 S10 5 speed tranny work in a F-body?
Old May 15, 2009 | 04:14 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
i was just curious on this subject...i know where i can find 5 speeds from s10's but will it work? i heard the internals are the same and they can hold up to a 350 but will it all bolt it place ok for my 87 TA?
Old May 15, 2009 | 05:25 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: 4.3 S10 5 speed tranny work in a F-body?
This will probably get moved to transmissions and drivetrain, but these 5 speeds are supposed to be the NewVenture 3500. Fullsize halftons used the NV3550HD. They are all rated for at least 350 ft-lbs, and are stronger than a T5. Beware of the version with the 4.03:1 first gear, better to use the version with the 3.50:1 first, and even so you will find that 3.42:1 is too much axle. Fifth is supposed to be 0.73:1 with the 3.50:1 first, and a 2.73:1 axle would be okay with a mild engine.
As far as installation, I think you will have to change your yoke, try to get the S10's driveshaft to take care of this. These used hydraulic clutch release, so this could be a snap or a real hassle, I don't know. T5s were installed canted 17 or 18 degrees, while the NV is not cant-able, so you may have to pound on your trans tunnel with a BFH. Lastly, the shifter. There are really no options but to modify the S-10 shifter, the stick is long, and no telling where it will want to pop through your center console.
Old May 15, 2009 | 05:32 PM
camaro3554gear's Avatar
Car: 1991 Z28 (sold), 1987 Buick GN
Engine: L98 TPI, bored 0.040 over
Transmission: TH350, 2400 stall, shift kit
Axle/Gears: 10 bolt w/eaton locker, 3.42 gears
Atilla is correct, the T5 does mount slightly turned which the S10 trans does not, and the shifter is in a completely different spot, without serious mods this will not work. In my opinion this would be effort not well spent, but thats just my opinion.
Old May 16, 2009 | 10:17 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
On the other hand, it's cheap, easy to get, and about comparable to an old Tremec TR3550. The good ratios for this ate much like the '85 2.8L's T5: in this case, second is 2.14:1 which is great in town with a mild axle ratio, and third is 1.39:1, while fourth is 1.00:1.
Old May 16, 2009 | 05:54 PM
9014josh's Avatar
Car: 1988 TA
Engine: TPI 350
Transmission: auto
Axle/Gears: 3.27's
alright thanks...sounds like more work than id wanna do lol
Old Mar 6, 2012 | 08:26 AM
HEAVY-T's Avatar
Car: 91 RS
Engine: 350 tbi
Transmission: W/C T5
Axle/Gears: 3:73
I just bought one of these for 200 bucks, my main concern is that the shifter may come up through the dash somewhere,lol. dont know....has anyone ever see this swap work out?
Old Mar 7, 2012 | 08:34 PM
fireburdluvr85's Avatar
Car: 91 formula ws6
Engine: 355 tpi OBDII
Transmission: 4l60E
Axle/Gears: 2.73 with 4th gen brakes
i myself contemplated this a few times as they seem pretty tough. believe they use a 32 spline output shaft. shifters seem to be in the same spot. im trying to upload a pic but it aint working out to well of them all compared side by side
Old Mar 7, 2012 | 09:12 PM
Car: 91 formula ws6
Transmission: 4l60E
here you go. after 20 mins trying to figure this out i hope it helps
Old Mar 7, 2012 | 09:26 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Use the Camaro tailshaft housing on the S10 trans
Reverse of what done here
http://www.inliners.org/Jack/T5tech.html
Old Mar 8, 2012 | 08:00 AM
HEAVY-T's Avatar
Car: 91 RS
Engine: 350 tbi
Axle/Gears: 3:73
vetteoz -
New Venture 3500 with a Borg Warner T5 tailshaft housing?
The tail shaft dosnt unbolt from the nv 3500.
fireburdluvr85 -
With Our-T5, note how far back the shifter is on the tailhousing. neither of those in the pic is for Our cars. Output spline count doesn't matter either.
I appreciate the thought process, just overlooking the info I gave ya.
ezobens
Aug 19, 2015 10:29 PM
Street Lethal
Aug 13, 2015 08:28 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
