Identify Motor
Old May 19, 2009 | 12:34 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Identify Motor
Hi, I know this has probably been drilled into the ground numerous times, and via searching i came along http://www.mortec.com/location.htm but i still need some help
in this general area: http://www.initips.com/~inittab/camaro/HPIM0124.JPG
i found what i believe to be 5.7L8 which identifies it as a 350. isn't the casting number suppose to be in the same area? i couldn't find it. Although there is a bunch of wiring harnesses in the way.
Basically what I want to know is what year the motor is. The valve covers are center bolt, and I also tried looking around the Waterpump area for another number cast into the block but couldnt find anything. Could somebody maybe post a picture with a nice big flashing red arrow pointing me to the promised land? Thanks.
Old May 19, 2009 | 12:55 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Identify Motor
The harness is hiding the casting number you want, but the "5.7LG" is evidence that this is an '87-up block. The last 3 digits of the casting number should be on the sides of the block, visible from underneath. The nubmers at the front are behind the water pump, just in front of the passenger side head, best seen from above. You may need to remove the alternator or a/c, whichever might be mounted in the way. That pad is actually an extension of the deck that the jhead gasket sits on, but the gasket won't be in the way.
Old May 19, 2009 | 12:57 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Re: Identify Motor
alright thank's i'll take a look. did they still have carb'ed motors after 87 or is this car more of a mixmutt than I think it is?
Old May 19, 2009 | 12:58 PM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Identify Motor
The '88 Police Caprice 350 was carbureted, but any year of heads can go on that block, so there's no telling without more info.
Old May 19, 2009 | 03:18 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Identify Motor
I'd also add that the numbers on block deck on the passenger side are stamped, not cast. Sometimes you'll miss them because you're looking for cast numbers and not stamped ones.
Old May 19, 2009 | 03:29 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Re: Identify Motor
alright so i crawled up under it. I didn't find anything on the side of the block on the drivers side but I did find some barely legible stuff on the passengers side. It looks like its printed upside down. the first thing on that side is "f 15" the second looks like "D N". if this isnt cast upside down i have no idea what it says I also took some new motor pics, don't know if any will help in identifying the motor. Looks like it has the emissions style dizzy and rochester emissions carb. I have not pulled the AC off yet because it looks like a nightmare but if none of this information helped I will.
Thanks for the help.
http:/www.initips.com/~inittab/camaro/new/
Old May 19, 2009 | 11:37 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Re: Identify Motor
I did just crawl under it again and managed to find 3 5 0 on the passenger side front. still cant find a date anywhere. I'll pull the A/C Compressor tomorrow and look behind it but i looked all around back there and didnt see anything, maybe it's just the angle. or the plate is just gone.
Old May 20, 2009 | 08:04 AM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Re: Identify Motor
So apparently after doing some research and digging around this is a TBI setup. Wonder what vehicle it came out of
Is there anything I should check to make sure the swap was done correctly? ECU etc.
Old May 20, 2009 | 11:05 AM
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: Identify Motor
about all I can add is that it sounds like a Canadian block, which isn't especially bad or good. It just is what it is.
Old May 20, 2009 | 03:26 PM
1ADan's Avatar
Car: 1987 Trans Am
Engine: LQ9/L92
Re: Identify Motor
If you can find the numbers, www.mortec.com has always been a great resource for me when it comes to ID'ing a block and heads.
Old May 20, 2009 | 11:17 PM
inittab's Avatar
Car: '88 camaro
Engine: TBI 350
Transmission: 5 spd
Re: Identify Motor
yeah I'm gonna start pulling some stuff off and see if i can get some better access to the casting number. thanks.
hydrolic144
Sep 8, 2015 06:55 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Redwhisper
Aug 26, 2015 05:02 PM
Linson
Aug 21, 2015 02:12 PM
Street Lethal
Aug 14, 2015 08:25 PM
