engine paint useing body paint good or bad
ok i found an engine that was painted 2007 sunburst orange now wont the paint peel after time or will it withstand the temperature i was told the aluminum was clear coated and so was the block buti am sceptical about it
because i would like to do it myself if it possible ? any ideas on what would happen ?
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: engine paint useing body paint good or bad
This topic comes up every 4 or 5 years in CarCraft or HotRod or one of those mags, about once per decade per mag, but I never paid attention because I'm not big on the idea of my engine matching the car.
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Just how hot do you think the block and heads will get to hurt the paint? If you overheat the engine too much, paint is the least of your worries. Coolant doesn't run hotter than 205* under normal operation and no painted parts should ever exceed that temperature except directly around the exhaust ports but they'll be covered by a gasket and manifold.
Keeping paint on the engine is more prep work than the type of paint. The metal needs to be spotlessly clean with no oils or dirt in the metal. It should then use a good primer and an etching primer is even better. After that, any enamel paint can be used.
I painted my engine with normal semi-gloss spray paint. Although you can see very little of the painted block, it's still holding up. Paint claiming to withstand 400+* doesn't mean much when the engine doesn't reach half that temperature.
Car: 85 Corvette, 91 Trans Am
Engine: V8
Axle/Gears: round ones!
Every engine I build for any of my cars I use base clear automotive paint to paint the block any color. It makes it look decent and VERY easy to clean off with just a hose.
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
If that did do the trick, be prepared to do a few quick oil changes as to get out any lingering fuel. That stuff just kills oil..
I use engine pant as a primer then automotive bace clear to finish it up. I work in a body shop.. did 2 blocks 4/5 years ago and had both hot tanked and the paint is still there just like new. the engine shop owner ask me whut i used for paint cuz it did not come off it just looked like new LOL.
Car: 89' RS
Engine: 350 TBI
Transmission: 4L80E/4L80E
The only place that gets too hot for the paint is around the exhaust ports.
Engine: V8
Here is the engine in my vette that was painted with the same paint that was used on the car.
Engine: V8
I did the same thing on a cheap set ($20) chrome set on the original motor.
ElPaleterro85
Aug 13, 2015 03:49 PM
