Temp Sending Unit
Old Jul 3, 2009 | 03:47 PM
smoothjazz's Avatar
Temp Sending Unit
Hi All,
Okay, I am trying to find my Temp Sending Unit on my 1983 z-28 305 engine.I know where the sensor is located( by the water neck housing), but I cant seem to find the actual Temp Sending Unit.If anyone can help would really appreciate it.
Smoothjazz
Old Jul 3, 2009 | 03:55 PM
armdale's Avatar
Car: 1984 Trans Am
Engine: 5.0 Litre H.O Modified
Transmission: 5 Speed Manual
Axle/Gears: 3.73 Limited Slip Posi-Trac
Re: Temp Sending Unit
Try this site -- free catalogs
http://www.ecklerscamaro.com/?cm_mmc...S|e|3360104489
Old Jul 3, 2009 | 04:33 PM
smoothjazz's Avatar
thanks for the reply.i found it after i wrote the message.i cant figure out what wire would connect to it.there is one wire thats not hooked up, but it only has a spade connection on it.none that would fit that part.
Old Jul 3, 2009 | 04:38 PM
armdale's Avatar
Car: 1984 Trans Am
It can be either, My trans am has a basically round plastic connector about 3/4 in in diameter with a smaller round hole in the center that clips down over the sender.
Old Jul 3, 2009 | 05:09 PM
smoothjazz's Avatar
i understand.maybe the actual connector that the spade connector was connected to fell off.I dont know.but hers whats weird.that wire wasnt hooked up before i put my edelbrock on,and the gauge was working.took off the edelbrock and put my quadrajet back on ,and now it does even move.getting 5 vdc at the connector.any other ideas?
Old Jul 3, 2009 | 05:53 PM
armdale's Avatar
Car: 1984 Trans Am
Maybe you trapped the wire under the intake or it got cut off?
Old Jul 3, 2009 | 05:55 PM
smoothjazz's Avatar
no, cause it was working after intake was put on.
Old Jul 3, 2009 | 06:09 PM
armdale's Avatar
Car: 1984 Trans Am
Could It have gotten pulled out of the wiring loom and fell under the car?
R13_Braz
Sep 18, 2015 05:00 PM
Springster
Sep 13, 2015 01:38 PM
ChristinaMarie
Sep 11, 2015 06:28 PM
hotrod1988
Sep 11, 2015 04:39 PM
Glowsock
Sep 5, 2015 07:48 PM
