Dented Oil Pan
Old Jul 9, 2009 | 12:14 PM
YoungMoneyVII's Avatar
Car: 1990 Pontiac Firebird T-Tops
Engine: V8 350 5.7 L TPI
Transmission: Overdrive 700R4 (Auto)
Axle/Gears: 9 Bolt/GU5AXLE,REAR3.23 RATIO3.23R
Dented Oil Pan
Yesterday me and my friend jacked my car up to try and change my starter and my friend said that my oil pan looked dented, if my oil pan was dented should I be alarmed? Whats the worst thing that could happen?
Old Jul 9, 2009 | 12:17 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Dented Oil Pan
If you didn't notice anything wrong until you saw the dent, don't worry about it.
Old Jul 9, 2009 | 12:29 PM
Re: Dented Oil Pan
Yeah the guys in the shop are changing my oil today id hope theyd be bright enough to tell me if the oil pan was a problem lol theyve only had it up on there jack in and out for like around 2 weeks
Old Jul 9, 2009 | 02:29 PM
el_muerte's Avatar
Car: '87 Z-28
Engine: LT1-topped 400
Re: Dented Oil Pan
might leak a bit more than usual depending where the dent is. otherwise not a big problem, don't think i've seen one yet that wasn't dented
Old Jul 10, 2009 | 10:29 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Dented Oil Pan
Being that the oil pump pick up screen is fairly clost to the bottom of the pan to have acess to as much oil as possable at all times dented oil pans can be a bad problem. However if it was causeing you a problem you probably would have noticed it by now.
Old Jul 11, 2009 | 11:33 AM
curacaoz28's Avatar
Car: 1985 Iroc-z28(sold) 1994 camaro z28
Engine: 350lt1
Transmission: 6-speed manual
Axle/Gears: ???
Re: Dented Oil Pan
if you dont have any problem dont worry., where is it dented in the front or back?
Old Jul 11, 2009 | 12:49 PM
JC63199's Avatar
Car: '86 Z28
Engine: Locked up 305
Transmission: 700R
Re: Dented Oil Pan
When they drop a valve it will usually dent the oil pan, but I doubt that is your issue here; the dent will be protruding. Probably just bumped something seeing how they sit so low to the ground; the dent will but up into the pan.
Old Jul 11, 2009 | 07:26 PM
50bmgshooter's Avatar
Re: Dented Oil Pan
the only time I have seen a dropped valve cause a dent in a oil pan is from the pistion coming apart and the rod doing the damage. and then a dropped valve is the least of your worries if you would please explain how you say a dropped valve will dent the pan?
Old Jul 12, 2009 | 05:18 PM
Re: Dented Oil Pan
well ??????
Old Jul 12, 2009 | 06:31 PM
Re: Dented Oil Pan
I think thats what he meant a dropped valve in many cases can have a catastrophic effect on the pistons the result of which could easy cause a dented oil pan among other things. However, again at that rate the pan is the least of your worries but he would deffinetly notice something like that lol.
Old Jul 13, 2009 | 07:41 PM
Stevolwevol's Avatar
Car: 86 IROC Z, 92 RS
Engine: 305 4bbl, 305 TBI
Re: Dented Oil Pan
The oil pan in my rs is dented a bit probably due to the previous owner not being aware of the limited clearance, but it is not causing a problem though. When I show my car to people I just don't say nottin lol
BDR
Nov 7, 2015 03:05 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
FtrSpeedy
Sep 7, 2015 12:11 PM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
