How streetable do you think this car would be?
Car: 82 Z28
Engine: 350 bored .030 over w/ 6-71 Weiand
Transmission: Turbo 400
Axle/Gears: Moser 9" w/ 4.56 gears
I have the opportunity to buy an '85 Trans Am that was built for drag racing. I don't have tons of details about the car, but I know the car has a 350 all motor, that he claims is about 575 hp. A TH400 tranny and a Moser 9" with 4.86 and a spool. He claims the car runs 6.60's in the 1/8th. I am not looking for a drag car...but a bad *** street car. If I changed the 4.86's to something like a 3.73 and an LSD instead of a spool...would the car be manageable to drive on the street? I know...this isn't a lot of info to go on, but what other possible trouble areas would need to be addressed? There is a good aluminum radiator with a 16" fan, so I don't think overheating would be an issue...what do you think?
Thanks!
edit: I tried uploading pics but it wouldn't work...I'll keep trying so you can see it!
Thanks!
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: How streetable do you think this car would be?
probably not so fun, the thing probably won't run on pump gas with octane booster, and the rpm range is probably so high that a 3.73:1 would feel like a 2.73:1 behind an LS6. Do a compression test, find out the cranking compression, and ask the guy what rpm he shifts at.
On Probation
Engine: several
Transmission: none
Axle/Gears: none
oh, by the way, it may be that he can get by on pump gas with octane booster, but using the taller gears you propose would increase the load on the engine, and that could induce detonation. Another reason to do the compression test.
Car: 82 Z28
Thanks man! I sent him your questions and I will let you know what he says!
Car: 82 Z28
Ok...he said he runs 110 racing fuel, 38 degrees total timingm 12.5 - 13 to 1 compression...the car also has a 4,000 stall converter. He didn't have compression numbers.
Thanks!
Thanks!
On Probation
Engine: several
Transmission: none
Axle/Gears: none
You'd need to make so many changes, I'd pass and look for something else.
Car: 82 Z28
Linson
Aug 21, 2015 02:12 PM
