305 or 350
Old Aug 16, 2009 | 07:09 PM
88birdform's Avatar
305 or 350
so guys i need to know. if someone told you they were selling you a car with a 350 not the stock 305 whats the best way to tell the difference. save actually finding the motor numbers
Old Aug 16, 2009 | 09:52 PM
thelast_graham's Avatar
Car: 1984 Chevy K5 Blazer
Engine: SD TPI 350 w/FIC Bosch IIIs
Transmission: 700R4 4X4
Axle/Gears: 3.08 front and rear w/ 33" AT tires
Re: 305 or 350
Numbers on the heads maybe? Receipts? Numbers on the motor is thebest way... if they have a problem with you getting the #s off the engine... Id say dont buy it...
Old Aug 16, 2009 | 10:06 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: 305 or 350
The ONLY way to know for sure is to get the numbers off the block - they are driver side, back end of block, on the top - impossible to see almost. There is no other way.
Old Aug 16, 2009 | 10:12 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
Re: 305 or 350
Agree. if there not welling to get a casting number off the block forget it.
and if they dont know what a casting is or where to find it then wow dont even give that car or its owner a 2nd thought. . .
Old Aug 16, 2009 | 11:11 PM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Transmission: Built 4L60e
Axle/Gears: 10 bolt, Eaton posi, 3.73's
Re: 305 or 350
That's a bummer when that happens (uncertainty).
Old Aug 17, 2009 | 08:52 AM
Re: 305 or 350
Maybe... get a little mirror and LED light... IDK??? LOL Ask him to bust his *** if he really wants to sell it to you and pull the damn thing out and get the #s like that.. HAHA
Old Aug 18, 2009 | 07:29 PM
88birdform's Avatar
Re: 305 or 350
good advice from all. but i already bought the car. i dont mind even if it is 305 i just need to know for my restoration. to ease everyones mind i only paid 950 for a running and it passed inspection, firebird
Old Aug 18, 2009 | 07:37 PM
Re: 305 or 350
Well thats good.. as long as you are happy... 305 and 350 parts are semi interchangable.. what do you need to restore on the engine?
Old Aug 18, 2009 | 07:42 PM
Guest
Guest
Posts: n/a
Re: 305 or 350
There are numbers on the side of the block as well, the last 3 of the casting number. That will tell you as well, and usually they are easier to see.
Old Aug 19, 2009 | 11:02 PM
mogojuice's Avatar
Car: 1992 RS
Engine: 305 TBI
Transmission: Stock, Auto
Re: 305 or 350
The block definatley is the only way to tell if the current motor is a 350, however you can run the vin through the decoder here and see what was originally put in it.
Old Aug 20, 2009 | 12:52 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: 305 or 350
I'd just tear a head off, but I LOVE wrenching more than most.
Old Aug 24, 2009 | 08:12 PM
88birdform's Avatar
Re: 305 or 350
i really dont need to restore the engine i just want to add a tpi and tune it up. i need to know what size it is for the new chip ya know
Old Aug 24, 2009 | 08:13 PM
88birdform's Avatar
Re: 305 or 350
where exactly would i find those numbers. i tried gettin in back with a light and a mirror but well i didnt see much
Old Aug 24, 2009 | 08:47 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 305 or 350
okay what you do is make sure cylinder #1 is at BDC pull the rockers off of cylinder #1 then jack the driverside way up into the air i mean way up and fill the cylinder with 50W oil put the plug back in and then jack up the passenger side and have a measuring can ready pull the plug and catch it all in the can turn the engine over to get as much oil as you can out then just do the math...
Old Aug 24, 2009 | 08:48 PM
Car: 91 RS
Engine: 350 vortec
Re: 305 or 350
or get a flashlight and mirror /camera if you need to take a bagillion pics and start comparing
Old Aug 25, 2009 | 02:22 PM
Transam_GTA's Avatar
Car: 1990 Trans am GTA
Re: 305 or 350
the block should have 5.0 or 5.7 stamped on it somewhere. Look around with a fashlight and maybe a mirror.
Old Aug 26, 2009 | 01:21 AM
New2Chevy's Avatar
Car: 1995 Formula
Engine: LT1 350
Re: 305 or 350
Best wishes finding it on the BACK of the block..try a mirror...that might work.
.Name:  305.jpg
xkingcodex
Feb 12, 2020 07:43 PM
Jake_92RS
Jan 28, 2020 10:37 PM
Dwayne614
Sep 28, 2015 08:33 AM
theurge
Aug 21, 2015 12:46 PM
st.evel07
Aug 13, 2015 06:15 PM
