Mild Wreck
Old Aug 20, 2009 | 06:38 PM
emi_16's Avatar
Car: 1983 Z28 Camaro
Engine: Crossfire Injection 305 V8
Axle/Gears: 2.8??? stock fer sure
Mild Wreck
I was coming out of work pretty pissed after yelling at my boss and throwing my name tag at him and quitting!.
coming home prolly doing like 40-45
and 90* curve was comin up.
i didnt care so i tried to take it but i couldnt and ended up hitting a curb
Size:  39.7 KBName:  100_0882Small.jpg
Size:  49.3 KBName:  100_0885Small.jpg
front rim lip is busted
the toe is drastically off too. havnt checked anything else.
the rear pass axle shaft broke at the hub. and my y pipe got completely crushed
but other than that... no body damage at all..
engine started right up too
wut do you guys think needs to be replaced?!?
the brake caliper adapter plate is bent too.
Old Aug 20, 2009 | 09:37 PM
Rolling Thunder's Avatar
Car: 86 T/A, 83 Z/28
Engine: 5.0 TPI, 350 2 X 4 bbl
Transmission: 4 speed auto, 5 speed manual
Axle/Gears: 3.23 posi, 3.73 std
Re: Mild Wreck
Well the very fist thing ide do is get a copy of the factory manuals body measurment and check to make sure the frame is still strait. These unit body cars dont take hits well and when they do the impact travels through the whole car. So befor you spend big money fixing it make sure its worth fixing thats all. For the axle i wouldnt even bother trying to fix it as you can get a nice used replacement probablt for less that it would cost to repair that one. Maybe even a stronger BW 9 bolt unit. Next if the tow is off something probably got bent so definitely thoroughly inspect the front suspension.
Old Aug 20, 2009 | 09:54 PM
emi_16's Avatar
Re: Mild Wreck
DO you think i can find those measurements in a Haynes Manual? or somewhere else
Old Aug 20, 2009 | 10:14 PM
Re: Mild Wreck
No information like that would be exclusively in a factory manual or some body shops that have spec sheets for particular cars which are really just copies of the factory manuals diagram. You might be able to find some one willing to scan you a copy out of their book as many of us have factory manuals and all 82-92 camaro/firebirds chassis were the same so it makes no difference which year manual they came from. If no one will though check your local libraries they even might have copies of old camaro factory manuals. I know the last one i was in had a factory manual for an 91,88, and 83 if im not mistaken. Online you might be able to find this info if you search and if you know someone that has access to alldata it might be on there. Worst case scnario i think i remember someone on ebay selling the spec sheets on ebay although at that rate you might as well buy the factory manual as you can find decent used ones on ebay for around $20 and they are 2-3 inches thick with information specifically on your particular year car. Its a very usefull very detailed manual with everything you could ever possably hope to want to know about your car and about the same price as a cheap haynes manual at your local autoparts store.
Old Aug 20, 2009 | 10:40 PM
emi_16's Avatar
Re: Mild Wreck
Ill see. but as of now. it doesnt seem like theres any chassis damage. amazingly no body damage either. car was still ruunning while i was checking the damage
Old Aug 20, 2009 | 11:04 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Re: Mild Wreck
remind me not to drive after quitting.. lol
Nah jk, it doesnt look like too much work.
Old Aug 21, 2009 | 10:53 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Mild Wreck
i think you need the following..
1.axle passengers side
2. brake adapter plate thing.
3.brake caliper
4.rotor
5.need custom y pipes
6.new lug nuts
7.rim
Old Aug 21, 2009 | 12:01 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Mild Wreck
3.brake caliper
4.rotor
6.new lug nuts
7.rim
How about a new car?
The axle shaft sheered off.. Impressive. I wonder if the tube bent. Hows the control arms look?
Backing plate. Yep that too. Caliper. Rotor. Oh yeah.
What about the front? Toe is off huh? Bet it's messed up there.
I'd part the car out and get another one that didn't crash.
-- Joe
Old Aug 21, 2009 | 12:54 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
Re: Mild Wreck
Ouch bro. Shitty. Going to cost a bit to get that fixed. The Jy is your best bet for the parts you need.
Old Aug 21, 2009 | 09:46 PM
emi_16's Avatar
Re: Mild Wreck
yea man its gonna cost quite a bit
but either its about 300$ in parts
or about 2000$ on a decent car like a old corrolla.
plus i got a system in this bad boy!
Old Aug 22, 2009 | 12:07 AM
Vader's Avatar
Re: Mild Wreck
3.brake caliper
4.rotor
6.new lug nuts
7.rim
You forgot the last one:
8. A new job.
Old Aug 22, 2009 | 02:09 AM
gotabekidding's Avatar
Car: 91 & 88 GTA, 89 Formy, 89 bird
Engine: 3 - 350 TPI, 305 TBI
Transmission: All 700R4's
Axle/Gears: unknown
Re: Mild Wreck
$2000 or $300 and a bit of work
hmmmmmmm
I would go with the least expensive
Old Aug 22, 2009 | 02:57 AM
bitchin_buick's Avatar
Car: 91' bird(WS6>>305TBI), 82'Regal
Re: Mild Wreck
I hope this at least happened out of view of your Ex-Boss! Good luck...
Old Aug 22, 2009 | 05:36 AM
icebird84's Avatar
Car: workcar Legacy Cruising 84 trans am
Engine: Ls1 99 corvette
Transmission: update working to get a T56
Axle/Gears: 2004 GTO IRS
Re: Mild Wreck
same happen to my brother ween he own my Trans am ,he decide to show off by make a u-turn only with the back wheels to much spin and hit the curb
photo be for digital camera ,it hard put the joke to English
(not allowed to spin the wheel "to much")
Old Aug 22, 2009 | 03:57 PM
emi_16's Avatar
Re: Mild Wreck
8. A new job.
awww that just hit me =[
like on the bottom side of my heart =[
Old Aug 22, 2009 | 03:59 PM
emi_16's Avatar
Re: Mild Wreck
yup. looks just like mine.
did he just replace the axle or the whole rearend?!?
or is it now at C4C?
Old Aug 22, 2009 | 06:04 PM
icebird84's Avatar
Re: Mild Wreck
first only axle for doner trans am, but later mixd 4.11.1 axles and Differential from Astro Van into the trans am 10 bolt
Fanatic1074
Oct 3, 2022 05:57 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
86IROC112
Nov 7, 2015 06:50 AM
FueledSoul
Sep 30, 2015 09:18 PM
tattmann
Sep 27, 2015 05:20 PM
