Rocker adjustment on a 219 cam?
Old Aug 26, 2009 | 03:13 PM
jackballs529's Avatar
Car: 1987 Iroc-z
Engine: 355/Edelbrkhds/lpe219cam/MiniRam/
Transmission: 700R4/3.27 9bolt
Got a 219 Cam/SuperRam setup. Got 1.5 roller tip rockers and the high tension LPE springs. Is their a suggested way to adjust with this set up other than what the stock GM shop manual says? Just curious, I have been trying to diagnose a Shakey, stumbly, low vacuum idle. Car runs great down the road. If your wondering, I've been through Fuel, ignition and vac leak checks as well as lots off new parts...
Old Aug 26, 2009 | 07:04 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The factory shop manual method is correct.
Old Aug 26, 2009 | 07:09 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: Rocker adjustment on a 219 cam?
yeah I did my rockers with the exhaust valve opening/intake closing method. Works great for me. I believe thats the way the shop method does it
Old Aug 26, 2009 | 08:04 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
I have a similar set-up as you... Have you taken it down the track or anything?
Old Aug 27, 2009 | 08:36 AM
Car: 1987 Iroc-z
Thanks for the help guys. I have not taken my car down the track yet. Only track we have close by is a 1/8 mile track which I don't really care to much about because everybody wants to know the 1/4 results. Still chasing gremlins anyway... Hey Orr, I checked out your twin turbo set up, all I have to say is WOW! that is unbelievable. Looks like a tuning nightmare to me though. I'd hate to pull up next to you at a red light, the turbo whistle alone would scare me off.
Old Aug 27, 2009 | 08:49 AM
Car: 1987 Iroc-z
Another quick question, could some miss adjusted rockers cause a sumble/shakey idle? I installed brand new lifters etc. I never re-adjusted the rockers after driving the car/break in time. Is that suggested?
Old Aug 27, 2009 | 05:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i have had rockers come loose before. Started to make noise but seemed to run ok. Readjusted them and everything was quiet again. But it does make sense if the rocker arms are loose and dont move the valve properly like the cam says, engine could run differently.
Theres been alot of testing on rocker arm/lifter preload and power output. Seems like less preload on the lifter helps make more power
Old Aug 28, 2009 | 10:09 AM
Car: 1987 Iroc-z
Thanks for the advise, if you guys can think of anything else that would cause a shakey/stumbly idle outside of the obvious, let me know. I have done the following.
2 sets of new injectors
Checked FPR, fuel pressure etc.
Checked for vacuum leaks
Replaced distributor and reset timing
Tuned chip/emulator every which way
Replaced TPS and IAC and soldered in new connectors
New MAF sensor
And a bunch of other stuff I can't think of
sweet_87_iroc
Sep 25, 2015 10:01 PM
gixxer92
Sep 1, 2015 04:32 PM
Brendankup
Aug 30, 2015 01:46 PM
SLNTSCPE
Aug 22, 2015 09:15 PM
