How to test ignition module
Old Aug 26, 2009 | 03:31 PM
dwinhofer's Avatar
Car: 1985 Iroc Camaro, 1974 type LT Z28
Engine: modified L98 corvette, L82
Transmission: 700r4, Turbo 400
Axle/Gears: 3.42, 3.42 posi
I need to know how to test my ignition module and I would like to know symptoms of a bad one. Also, how often do they go out. My car is an 1985 with a 1989 engine and I know it has never been changed. I have an ACCEL Supercoil on the distributor and was wondering where to get new screws to mount it to cap.
Old Aug 26, 2009 | 05:10 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: How to test ignition module
- symtom - stalls when hot.
There's a procedure using a multimeter I believe. Pull out your haynes, i'm not certain on how to do it on the '89 engine. What kind of engine is this?
Old Aug 26, 2009 | 05:38 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
pull it out and take it to your auto parts house, most all can check it, but if your going to remove it might as well replace it accel module or something like it for a chaep as they are
Old Aug 26, 2009 | 05:58 PM
FSTFBDY's Avatar
Car: 92 Z28
Engine: Boosted LSX
pull it out and take it to the auto parts store. They will test it.
The problem with a bad one is imtermitent unless its 100% dead. My buddy Gary just went thru hell 5 of em now. They get hot and die. He will get a NO START issue when Hot.
Let it cool down and starts up fine. will run ok untill it gets hot and starts to break up under load and ont rev past 2k.
If left in part it revs fine.
Old Aug 26, 2009 | 06:00 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
i have my book with me. and i remember theres no procedure for testing the module. but there is a procedure for testing the coil (even though theyre very vague instructions)
just take it to autozone. i took mine there when i had a stall while hot problem
Old Aug 27, 2009 | 09:26 AM
dwinhofer's Avatar
L98 out of a 89 corvette
Old Aug 27, 2009 | 09:31 AM
dwinhofer's Avatar
I have it out so I ordered one from carquest. If it goes bad again I will get an accel one an put it in. I get it this morning and will put it in and see if it works.
Old Aug 27, 2009 | 06:41 PM
dwinhofer's Avatar
I put a new one in and it seems like it fixed my problem.
pjsparts
Oct 29, 2025 06:39 PM
gta892000
Aug 11, 2019 11:16 AM
MM2Robinson
Oct 1, 2017 09:16 AM
BumpaD82
Feb 26, 2016 02:57 PM
Johnoooooo
Sep 22, 2015 08:55 AM
