oil leak help.. what is this and why is it leaking??
Old Sep 1, 2009 | 10:51 PM
thunder85's Avatar
Car: 1988 firebird trans am GTA
Engine: 5.7L w/hsr
Axle/Gears: posi 3.23
Hey.. i've been chasing an oil leak for a while and finallly found what was leaking oil.. turns out it wasn't the oil pan or the oil pressure gauge; it was a sensor of some sort above the oil filter. what is this and why would it be leaking oil? When I noticed it was coming from that, there were droplets of oil on it, oil below it, and dry metal above it. whats it called so I can replace it? thanks! (sorry for the poor picture quality)
Old Sep 1, 2009 | 11:06 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: oil leak help.. what is this and why is it leaking??
oil pressure sensor i believe. its cheap, DONT go with Autozone (autosuck) go napa, a/c delco. try even tightening it. i tells the Fuel pump to pump, with you disconnected it. your car wouldnt run. its a saftey sensor. in case someone flips the car, engine stops but the fuel line bursts and sets the car on fire. Im on a highway to hell, -ac dc.
Old Sep 1, 2009 | 11:15 PM
thunder85's Avatar
Engine: 5.7L w/hsr
i'm not certain tightening it would do any good.. it appears to be coming from between the metal body and plastic sensor housing. I will swing by the gm dealer and pick up an acdelco. thank you
Old Sep 1, 2009 | 11:19 PM
the stealership? if you do, be cool with the parts guy. dont call him bro or anything, just be cool, and talk about the babes in town. then ask for a discount. IF you lucky, can get it for 20%+ cheaper. just gotta chill. its a head game. i once got a PRom over the phone at a stealership, at StEALER price. just got be cool.
Old Sep 1, 2009 | 11:21 PM
thunder85's Avatar
Engine: 5.7L w/hsr
sadly, if i want acdelco i gotta hit up the dealership. they closed the acdelco parts shop a couple years ago here in watertown, ny.
Old Sep 1, 2009 | 11:54 PM
not even a napa, youre going to have wait anyways for the part to be shipped, maybe an online store in order? rockauto.com? saves mula
Old Sep 2, 2009 | 04:28 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
thats the oil pressure switch for the fuel pump if your fuel pump relay dies it senses oil pressure and kicks on the fuel pump so you don't get stranded any where just make sure when you order it it has a square 4 plug connector
Old Sep 2, 2009 | 05:33 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
This... it's not really a safety thing - it's a redundancy thing.
Old Nov 3, 2009 | 03:08 PM
Stangski09's Avatar
Car: 1988 Pontiac Trans Am GTA.
Engine: 385 stroker sbc
Transmission: TKO600
Axle/Gears: Moser 9" 3.70 Wavetrac
What is the part number for this sensor? Is it the same for an 88 as well?
Old Nov 3, 2009 | 04:24 PM
grumpyvette's Avatar
http://www.ecklers.com/product.asp?p...52&dept_id=153
Old Nov 4, 2009 | 06:59 PM
Stangski09's Avatar
Nah that ain't it. But I round it. Thanks.
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
tgp1990
Sep 4, 2015 06:24 AM
