Rusty Cams
Old Sep 15, 2009 | 09:23 PM
turbo_jimi's Avatar
Car: 85 Z28 & 86 TA
Engine: 350 Crate Motor & 305 TPI
Transmission: 5-speed & 700R4
Axle/Gears: 3.23 Open End & 3.27 posi
Rusty Cams
Hi,
Is there any way to clean up a camshaft that's been exposed to the elements and has surface rust without damaging it?
Thanks,
TJ
Old Sep 15, 2009 | 09:30 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Transmission: TH350, 8" Converter
Axle/Gears: S60 with 4:11 and Locker
Re: Rusty Cams
take a fine scotch brite pad and some WD40.
Old Sep 15, 2009 | 09:53 PM
jv9999's Avatar
Car: '87 IROC/'68 SS
Engine: 5.7L/350
Transmission: 700R4/Muncie 4-spd
Axle/Gears: 3.27 9 bolt / 3.31 12 bolt
Re: Rusty Cams
But if it's pitted, it's done.
Old Sep 16, 2009 | 09:00 PM
kens86's Avatar
Car: 1986 Camaro
Engine: 436" SBC
Re: Rusty Cams
exactly. I should've mentioned that.
Old Sep 17, 2009 | 03:58 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Rusty Cams
Is it a roller? If its a roller, and the surface rusting is light, then you could probably get away with cleaning it up with some light oil + fine grit sand paper (> 600 grit). If its a flat tappet, then forget it.
Old Sep 17, 2009 | 04:15 AM
Twin_Turbo's Avatar
Re: Rusty Cams
If it's a roller and it's pitted forget it too...the pitting will imprint in the roller and it'll be gone in no time.
Old Sep 17, 2009 | 10:55 AM
turbo_jimi's Avatar
Car: 85 Z28 & 86 TA
Re: Rusty Cams
They're probably not worth the time then...time for the trash.
Thanks for the responses.
Old Sep 17, 2009 | 11:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Re: Rusty Cams
If it is a large "Solid Roller" then you could have it reground. They were used race cams with high .700 lift. We sent a few off and had them reground to use in some drag motors. It cost about $175, but the cores were cheap.
Prodigious
Theoretical and Street Racing
35
Apr 13, 2021 02:37 PM
Jorlain
Oct 8, 2015 01:57 AM
customblackbird
Oct 1, 2015 04:30 PM
Strick1
Sep 4, 2015 07:11 AM
z28guy134
Sep 1, 2015 11:50 PM
