To flush engine, Or not to flush engine
Old Sep 24, 2009 | 05:23 PM
89RS_82Z's Avatar
Car: 89RS(other cars & pics in vBgarage)
Engine: LO3, 305 TBI Mildly Modified
Transmission: BakerBuilt 700R4 w/B&M Megashifter
Axle/Gears: 3.23 Auburn Pro Series LSD
well, i now got 150k on the clock got a little bit of start up smoke (but hey thats chevys pre start-up lubercation ) anyway oil psi runs about 20-25 at idle (at oper. temp) and about 35 cruising, i am running 15w50 mobile 1 , personaly i think the engine has enough on miles on it to run a heavy oil and its driven like a car should be
i have had it since 100k / 8 years ago, i think the p.o. ran quaker misteak because it has some sludge in it when you pop the vc's off
so should i flush it with engine flush it (gunk,diesel, trans fluid) or should i just let it be
Old Sep 24, 2009 | 08:06 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: To flush engine, Or not to flush engine
i have flushed engs. on all my cars/trucks about twice a year . ( as old as i am i have had a few ) anyway on our cars sludge build-up is a problem on the drain holes of the cylinder heads . when they become sludged up oil can't drain as fast as it should back to crankcase . the drains are at the lower front and rear of the cylinder heads . next oil change , pull valve covers , clean drains with screwdriver-probe-what ever is handy . then blow compressed air through them . re-install valve covers , add flush agent , run car reasonable for a few miles , change oil . has worked for me . good luck .
Old Sep 24, 2009 | 08:37 PM
89RS_82Z's Avatar
yea im thinking about doing it before CTC
Old Sep 25, 2009 | 05:35 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I'd "flush" it slow.
At next oil change put in 1 quart of synthetic and the rest dino juice.
Next change - 2 quarts of synthetic and the rest dino juice.
Next change - 3 quarts.............
Get the picture?
Old Sep 25, 2009 | 04:13 PM
89RS_82Z's Avatar
all ready running synthetic, been running a synthetic blend since i got it, and since about 20k ago been running mobil 1 full synthetic
Old Sep 25, 2009 | 04:49 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Then as long as you're religious about changing your oil, you shouldn't need to flush.
Any gunk that is in there will work itself out with the synth.
Old Sep 25, 2009 | 04:54 PM
musclecar70sfan's Avatar
Car: 91 Trans Am 'vert
Engine: LB9
Axle/Gears: 3.45 9 bolt
Maybe seafoam?
Old Sep 25, 2009 | 05:00 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Do it if it makes you feel warm and fuzzy.
I seafoamed one of mine and didn't get the wonderful smoke storm that many here claim to get.
It won't smoke if you didn't need it.
Old Sep 25, 2009 | 05:10 PM
Engine: LB9
They say that it smokes more when your engine is cruddier... so if yours didn't smoke much that probably means it was already pretty clean.
I'm just reiterating what you're saying LOL.
Old Sep 25, 2009 | 05:11 PM
89RS_82Z's Avatar
did you put it in the oil or through a vac line
Old Sep 25, 2009 | 05:53 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I restricted a vacuum line at the throttle body. I wanted it to hit ALL runners not just the last couple by using the brake booster line.
Old Sep 26, 2009 | 06:44 PM
89RS_82Z's Avatar
yea than your engine was pretty clean . . . . . . . . .seafoam is the closest you going to get to something like BG that they use a the stealership
you can seafoam the oil to get the crud out but engine flush is cheaper and works better, plus i rather use seafoam through my intake
Old Sep 27, 2009 | 07:52 AM
DartByU's Avatar
Car: 92 Camaro RS
Engine: 305 TBI
I've run Mobil 1 10W-30 in my car since it was new, first oil change at 1000 miles, then every 5 to 10K so it don't have any crud inside, but I have used 1 qt. of automatic trans fluid on a few other vehicles and it seems to clean really good, drive it for a week and then change fluid. I tried Seafoam on my Camaro a few years ago by pouring it directly down the throttle body bores and didn't get much smoke at all.
Old Sep 27, 2009 | 05:08 PM
RED86Z28's Avatar
Car: 1986 IROC
Engine: 355" TPI
The old transmission fluid trick is bogus. The gunk stuff works but why bother if things are working well and pressures are good.
eightsixseven
Dec 16, 2024 01:50 PM
Jeremys87
Jul 14, 2022 09:08 PM
Infested
May 22, 2018 11:56 PM
z28_AJ
Aug 27, 2015 08:59 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
