removing emmisions pump.
Old Oct 9, 2009 | 10:49 AM
Donald87FB's Avatar
Car: 93 firebird formula
Engine: 350 Lt-1
so my emmision pump is froze up. so where i live there arent any restrictions about emmisions. so seeing as i dont have a belt on it(and it dosent work) would removing it do any good? i know its going to make alot more room is this a good idea?
p.s. its cabureted, so its not gonna mess with my ecu.
Old Oct 9, 2009 | 11:34 AM
novafirebirdguy's Avatar
Car: 90 Formula WS6, 86 Sport Coupe
Engine: 305 TBI, 2.8 MPFI
Transmission: 700r4, 700r4w/vette servos
Axle/Gears: 2.73 Open, 3.42 Open
Re: removing emmisions pump.
Rip it off and all the hoses and crap that connect to the exhaust manifolds. It's all dead weight. Just make sure you plug the holes in the manifolds, they are 1/4" plugs I believe
Old Oct 10, 2009 | 01:28 AM
88formula305tpi's Avatar
Car: 1988 Firebird Formula WS6
Engine: 305 tpi lb9
Transmission: 5 speed
Axle/Gears: 3.45
can u leave the tubes on with the check valves on them?
Old Oct 10, 2009 | 09:02 PM
firebird904's Avatar
Car: 1988 camaro
Engine: cammed 3.1
Axle/Gears: 10 bolt 3.42
I had the tubes on mine for the longest time before i finally got around to plugging the holes i used 1/4 brass plugs from lowes but you should be fine mine didnt leak at all
Old Oct 10, 2009 | 09:13 PM
Stephen's Avatar
Car: 87 GTA
When I bought my 87 GTA 4 years ago, the pulley was off the pump, the hoses after the manifold tucked away, so as not to be an obvious disconnecting something.
An ECM doesn't care about it any. As long as what comes out is clean, that is what the O2 sensor sees & an ECM wouldn't care HOW it got clean.
Besides....Even without the smog pump, my GTA burned CLEAN, even with emissions tests.
Pull it off. Won't affect anything, either way.
Old Oct 10, 2009 | 09:36 PM
Donald87FB's Avatar
Engine: 350 Lt-1
alright sweet, all that stuff is coming off then. and thanks for the heads up on the size of the plugs. i was wondering about how to plug.
Old Oct 10, 2009 | 10:02 PM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
sweet. you can sell you ari diverter for three hundo. btw money in bank
Old Oct 10, 2009 | 10:26 PM
Donald87FB's Avatar
Engine: 350 Lt-1
so another question is what am i going to have to plug when i take the actual pump off? is there gonna be a big hole there? i cant say ive ever messed with emission pumps before.
and as a little off the subject, can you just beat out the cat? i know you can do that to most cars, i dont have the money to upgrage my exaust and i thought that would help too, free up a little more air flow.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
HP52TA
Feb 3, 2018 10:51 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Eric-86sc
Sep 7, 2015 02:10 PM
Glowsock
Sep 6, 2015 06:40 AM
