Speedometer help
Old Oct 20, 2009 | 07:39 AM
custom13's Avatar
Speedometer help
You guys helped with my last question so i was hoping for some more advice.
I have a 83 Camaro with a speedometer that does not work at the moment. thats one part of a car i do not understand completly and was hoping someone could point me in the right direction as to where to start looking.
Basically what could cause a speedometer to not work.
Thanks for your help again, you guys are awesome.
-AF
Old Oct 20, 2009 | 08:47 AM
transam85dudeman's Avatar
Car: 85' Trans Am !best car ever!
Engine: 305tpi 215hp LB9 two bolt,
Transmission: th-700r4
Axle/Gears: stock (3.27)
Re: Speedometer help
not being connected to the tranny. broken plastic gears on the cable.
Old Oct 20, 2009 | 10:06 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
https://www.thirdgen.org/forums/inte...eedo-woes.html
You may have a two-part cable with a transducer (for cruise control) between. If so, either cable might be the culprit.
JamesC
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
Elephantismo
Feb 13, 2019 12:51 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
Bigold4x4
Sep 28, 2015 05:21 PM
