Engine Break in Help!!
Old Nov 25, 2009 | 01:34 AM
t_long927's Avatar
Hello everyone. I have just put in a new camshaft and lifters by edelbrock. I also had the heads and intake manifold redone. I have heard that I should use a zinc oil. Is this true and if so what kind. I went to the local O'reily's and they did carry anything like that. They did give me a zinc additive and they said to just use a straight 30w oil with no other conditioners... Please help. I need this info so I can start this bad boy up..
Old Nov 25, 2009 | 04:20 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: Engine Break in Help!!
flat tappet or hydraulic?
Old Nov 25, 2009 | 08:20 AM
86ttopbird's Avatar
Car: 86 Firebird SE
Engine: 2.8L
If its a flat tappet hydraulic then youre going to need to keep the RPM's at around 1500 for the first 15 mins or so to break in the lobes on the cam. Roller cams are just start and go as they have next to no friction due to the roller tips on the lifters. I have used just straight 30 weight oil for break in. After the cam break in is done, change the oil again and youre good.
Old Nov 25, 2009 | 12:39 PM
t_long927's Avatar
it's a flat tappet.
Old Nov 25, 2009 | 02:27 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
A diesel oil rated CI-4++/SL will have the necessary ZDDP. Straight weight isn't important.
What did you use for assembly lube on the cam lobes?
Old Nov 25, 2009 | 07:31 PM
oil pan 4's Avatar
Car: 89 Firebird
SH rated Mobil 1 "racing 4 T" 10w-40 has so much zinc it would be over kill to say the least.
GM E.O.S. Assy lube is what I use.
Old Nov 25, 2009 | 09:20 PM
t_long927's Avatar
I just used the molly lube that cam with the cam and lifter kit...
Wylecoyote08
Nov 6, 2015 03:46 PM
MY87LT
Aug 17, 2015 08:43 AM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
