Tons of mods - Will it pass smog test?
Car: 87 Formula
Engine: BluePrint 355 w/ 600cfm Carb
Axle/Gears: New axles, Yukon 3.73 & Eaton Posi
So, the car is an 87 Formula, had a 305 and I replaced it with a 350 crate engine with a big cam and 2.02 heads. It has the Edelbrock Performer EPS intake and a 600cfm carb, headers and no cat. All emissions equipment is gone. No pump, air tubes, egr, nothing. The computer has also been removed since there was nothing left to control :-) In Georgia the DMV-like place (not really DMV, more like a title place) made the mileage exempt because no one really knew the exact mileage.
Anyway, there is the possibility that I will be moving to California soon. Question is, what the hell would I need to do about the car? With a car rebuilt like that, what are the parts that are required to be there? What can be done? Does anyone know for sure?
Car: 89 Firebird
Re: Tons of mods - Will it pass smog test?
Are you sure there was nothing left for the computer to control?
In my car the ECM locks and unlocks the torque converter.
Car: 87 Formula
Had that taken care of when I had the new TC put in.
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Option 1) Don't move to Cali.
Option 2) Sell car before move to Cali
Cali is going to require all OEM factory equipment back on the car in Cali - that means going back to the original setup.
Car: 87 GTA
In California, they'll pop the hood, see what appears to be TBI is a carb, close the hood......"You fail." They won't even bother running the test, since you fail on visual basis, regardless of what comes out the end.
You'll hafta either.....
A: convert back to EFI
B: pay extra for an illegal sticker
C: don't move to California, but even other states would fail you on the same thing.
Transmission: 4L80E/4L80E
Take that car to California, plan on it being on a trailer any time it's on the streets.
You could try to make it look like an '87 Caprice 350. That carb will have to go, along with the distributor - computer controlled carb and distributor are the only things you can use. It'll need a cat, A.I.R., and EGR. I don't know exactly what a "big cam" is, but if overlap is excessive, it'll cause you to fail the sniffer.
Car: 87 Formula
RE: Stephen
Actually from the factory it was carb. the 87 Formula with a 305 was the last Firebird to be offered with a computer controlled carb. You could get it with TBI but this one wasn't.
Car: 87 Formula
Well this car was mainly just a hobby, something to keep me busy. I love it but I'm not going to let it keep me from moving. From what you guys say and from what I've read today I would definitely have a ton of work to do. So, if I do end up moving this summer then I guess I'll sell my car.
Thanks for the info.
Car: 87 Formula
Thanks for all the help guys
I was serious about the trailer comment. If it's just a hobby, make the track your hobby.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
