Car won't start
Old Nov 29, 2009 | 03:51 PM
86GreenTransAm's Avatar
Car: 1986 Pontiac Trans Am
Engine: 305 TPI FI
Car won't start
hello i have a 1986 trans am i just replaced the starter and alternator and still doesn't want to start up no indication on the gauges but the lights in the car work but nothing else doe's anybody have any suggestions?
Old Nov 29, 2009 | 04:27 PM
ploegi's Avatar
Car: 1988 Pontiac Firebird Formula
Engine: 5.7 TPI
Re: Car won't start
Did you hook up all the wires to the fat terminal on the starter? There are three or four of them......
Old Nov 29, 2009 | 06:24 PM
Engine: 305 TPI FI
Re: Car won't start
yes i have all the connections on correctly today i tried changing the power cable wire and ground cable wire from the battery to the alternator and still nothing.
Old Nov 29, 2009 | 08:01 PM
ploegi's Avatar
Engine: 5.7 TPI
Re: Car won't start
Does anything happen when you turn the key to the on position? Does the radio, etc. work?
Old Nov 30, 2009 | 09:32 AM
ImpendingDoom's Avatar
Re: Car won't start
Is your car cranking at all? If its cranking and won't fire, your fuel pump might not be sending any gas to the fuel rails. I'm having the same problem on my Z28 and so far im still trying to diagnose the problem. It might be electrical or my fuel pump may have taken a $#@!.. Hopefully not..
Old Dec 1, 2009 | 02:32 PM
Engine: 305 TPI FI
Re: Car won't start
only the lights inside the care turn on when i try to start the car nothing happens no crank and gauges don't turn on
Old Dec 1, 2009 | 02:33 PM
ploegi's Avatar
Engine: 5.7 TPI
Re: Car won't start
Sounds like you might have missed one of the power feeds at the starter motor, or, one of the fusible links died.
Old Dec 1, 2009 | 02:36 PM
Engine: 305 TPI FI
Re: Car won't start
i checked all the fuse's on the car none of them are blown i double checked the connections on the starter
midge54
Dec 27, 2019 04:14 PM
Brcharrelson
Aug 26, 2015 07:47 PM
justin57
Aug 20, 2015 07:05 PM
ZsTransAm
Aug 11, 2015 07:30 PM
killer777
Aug 8, 2015 02:47 PM
