oil pressure needs to hit 30 before start.
Old Dec 15, 2009 | 08:26 PM
firstcamaro89's Avatar
Car: '89 camaro RS
Engine: 305 TBI
Transmission: 700 R4
My 89 camaro lo3 takes a long time to start. it doesn't start until the oil pressure hits 30 psi. is this normal? and it has to crank for a while before it hits 30. i've searched and can't find anything like this. any info would help thanks
Old Dec 15, 2009 | 09:47 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: oil pressure needs to hit 30 before start.
Does the fuel pump prime when you turn the key on?
Old Dec 15, 2009 | 09:48 PM
91RS_Charlotte's Avatar
Car: 1991 Camaro RS
Axle/Gears: 3.42 Std
I think it should be 4 PSI.
Old Dec 15, 2009 | 10:17 PM
ajblbv's Avatar
Car: 83 Z28
Engine: 355
doesn't your car have to be started to get oil pressure? or do you mean stay running?
Old Dec 15, 2009 | 10:18 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
I know there is a switch that will not let the engine run below a certain preset pressure, but its definitely not 30psi... probably more like 5psi. And that switch shouldn't keep it from starting anyway... I think it just kills the engine if the pressure drops too low.
Old Dec 15, 2009 | 11:12 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Bad fuel pump relay - swap it out with the fan relay beside it to test (assuming your fan works). Bad fuel pump relay means the pump won't prime before start - thus you have to keep starting the car until the oil pressure builds enough to run the pump off the oil pressure sending unit. It takes time to build that oil pressure off the starter, and then takes time to get the fuel pumped up to the TBI.
Old Dec 15, 2009 | 11:54 PM
Car: '89 camaro RS
Engine: 305 TBI
Where are the realys? i've been looking and can't find out where it is.
Old Dec 16, 2009 | 12:45 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
The oil pressure switch works in parallel with the relay as a backup should the pump relay fail.Under normal conditions , the pump relay pressurises the rail for 2 sec ; key on, then turns off.When OP over 4psi while cranking , the switch turns the pump on again and when engine fires the relay supplies power to the pump also.
Should oil pressure drop below 4 psi the switch will obviously drop out but the engine will continue to run on fuel supplied via the pump relay.
There is no low oil pressure engine cut off
Old Dec 16, 2009 | 03:07 AM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Im just quoting this for emphasis.
Old Dec 16, 2009 | 04:40 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
It is a common miss-conception because the only oil pressure switch most people have come across is on a carb car where it's use is to stop the engine should the OP drop below a set pressure.
Old Dec 16, 2009 | 01:28 PM
Car: 1992 RS
Engine: Carbed 350
Relays are located on the driver side firewall, between the brake booster and the fender. There will be a bracket there, held on the firewall with two 10mm screws - the relays are are the inside of that bracket (the firewall side of the bracket). There should be two, 1 is for the electric fan, one is for the fuel pump - the electric fan will have a large diameter black wire with a red stripe. Mark the fan relay (so you remember which is good), swap the two, and see if the car starts better (you should also hear the fuel pump prime). If you don't hear the pump prime NOW, but hear it prime AFTER the swap, then you know the relay is bad - replace, about $8.
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
