Whats up with my gas gauge? I cant tell how much gas I have.
Old Dec 24, 2009 | 02:50 PM
3rdGenGuy6792's Avatar
Car: 1992 Camaro Z28
Engine: 5.7 350 TPI
Ok so I have a 92' Z28 350tpi and I can never tell how much gas i really have. Lets say the gauge is at a half a tank at idle, well as soon as I start giving it gas the gauge will rise to 3/4 tank and then upon slowing down or braking, it will drop BELOW the half tank line then slowly rise up.
I thought my gauge was screwed up but then remembered my 4th gen had the same problem.
Any way to get a somewhat accurate reading? Should I go by what it says when idling or in park?
Old Dec 24, 2009 | 03:05 PM
Engine: 5.7 350 TPI
Re: Whats up with my gas gauge? I cant tell how much gas I have.
Oh also my coolant temp gauge doesnt even work. It just stays at 110 or 100 or whatever the lowest is, no matter how long the car is turned on or driving. The car is running great, no problems whatsoever, but could this be a problem? A broken gauge?
Old Dec 24, 2009 | 03:18 PM
I_R_O_C_Z_2_8's Avatar
Car: 1991 Trans Am GTA
Engine: 350 tpi
That sounds exactly like my car i know how much gas i have only when i park the car...it moves up when i step on it and drops when i brake.
Old Dec 24, 2009 | 04:58 PM
FastChick's Avatar
Only time you know how much fuel it has is when you fill it up, then you have 15.5 Gal. Drive it until your at 1/2 tank parked and fill it again, do the same at 1/4 tank, then you have markers. I know my car gets 100 miles until the gauge even gets below full then gets about 50 miles per 1/4 tank.
Old Dec 25, 2009 | 03:07 AM
omnipotentgoku's Avatar
Car: 1987 IROC Z
Engine: 350 TPI L98 block
Seriously... I want to tell you to "use the force" ... but my ultimate solution to this was to get a digital fuel gauge.
Old Dec 25, 2009 | 05:48 PM
Engine: 5.7 350 TPI
Hmm im looking into some digital gauges. I might even get a couple other gauges and just put them in a double/triple gauge pod. Gotta love that look haha.
Any suggestions on a cheap fuel gauge, preferably one that lights up for night? I checked jegs and summit but a good gauge usually runs about $40-$50
I mean if I have to ill get one but id rather get a cheaper one
Old Dec 25, 2009 | 10:31 PM
Engine: 5.7 350 TPI
Hows this gauge? Looks pretty cool. Good price also. Another thing, how hard is it to install fuel gauges? Should I just get it professionally done or would a self install be okay? Thanks
http://cgi.ebay.com/ebaymotors/Digit...323#vi-content
Old Dec 25, 2009 | 11:00 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
That would indicate a problem with the gauge sender unit in tank being worn ( not uncommon ) or damaged.
Changing the gauge is not going to give better readings if the sender unit is sending out a dodgy signal.
The gauge is only showing the info given to it by the tank sender unit
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
TA8487
Interior Parts Wanted
Aug 23, 2015 01:34 PM
wayshegoes
Aug 17, 2015 12:00 PM
BurlyChev
Aug 16, 2015 09:08 PM
