89 Firebird Running Rough, White Plugs
Old Jan 16, 2010 | 04:48 PM
1989bird305's Avatar
Car: 1989 Firebird
Engine: 305 V8 TBI
Transmission: Automatic
Hey everyone, It has thankfully been a while since I have had problems with the Firebird, but now I am back.
The car is running rough when I accelerate, but idles fine and runs fine when I am holding a steady speed.
Fuel pump and filter are fairly new and Injectors are spraying nicely (TBI).
I pulled the 2 front spark plugs and they are both white and starting to blister. Plugs are AC Delco R45TS.
I am also getting a moderate amount of white smoke in the exhaust.
Engine is completely stock 305 with no visible leaks.
Ideas?
Old Jan 16, 2010 | 05:52 PM
84Z28406's Avatar
Car: 1984 Camaro Z28 T-tops
Re: 89 Firebird Running Rough, White Plugs
How's your coolant level looking? White smoke in the exhaust can mean a head gasket.
Old Jan 16, 2010 | 09:00 PM
Car: 1989 Firebird
Engine: 305 V8 TBI
Coolant level is good. I've never seen a head gasket leak cause the spark plugs to overheat like this.
Old Jan 17, 2010 | 01:41 AM
Car: 1989 Firebird
Engine: 305 V8 TBI
I was looking at the fuel injectors again and I guess they could be the problem. They are spraying in a pretty decent cone, but not quite how I think they should.
I'll check that out in the morning.
Until then, other suggestions would be appreciated.
Old Jan 17, 2010 | 01:48 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
white plugs can be an indicator of coolant in the system....is it all eight plugs??
white smoke is also a indicator of burning coolant.
Old Jan 17, 2010 | 01:55 AM
Engine: L98 494hp
also, it could be a head and or intake gasket leaking, which could also cause an air leak, and make the plugs run hot, but more likely is the coolant on plugs turned them white, and with white smoke, you have an internal coolant leak.
Old Jan 17, 2010 | 09:52 AM
jamon8's Avatar
Car: 88 GTA "Cocaine"
Engine: 350 tpi
when you put new plugs in use a lower heat range 43's
you could also be running lean
Old Jan 18, 2010 | 11:03 AM
Car: 1989 Firebird
Engine: 305 V8 TBI
I was checking on the coolant issue. Found that there is a significant amount of rust in the coolant. And for some reason, the reservoir was not feeding to the radiator. Coolant level was low. I spent all day yesterday messing around with it.
If it is the intake manifold gasket, anyone know where to get a good quality replacement?
If it is the head hasket, anyone want to buy a car?
Old Jan 19, 2010 | 01:06 AM
84Z28406's Avatar
Any parts store should sell an intake gasket. Check Napa. Don't sell the car because of a head gasket or cracked head. You can remove and replace the top end in a day, two if you really take your time. If the heads cracked, the local u-pick lot will have a pair of chevy heads and they might cost you $50.
Vintageracer
Jan 10, 2020 05:33 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Bradsaundry
Aug 12, 2015 12:34 AM
Sherpajames
Aug 7, 2015 06:56 PM
