Blew my water pump gasket yesterday....
Old Jan 19, 2010 | 06:55 PM
mbolte's Avatar
Car: 1987 Camaro
Engine: 350 dart ies comp cam intake carb
Transmission: 700 r4, shift kit, 2400 stall
Axle/Gears: 10 bolt stock
Its the second time I've done it, did the same thing about this time last year...luckily it didn't get to hot, but any hints tips or reason why so I can get this next one put on right....
PS its an edelbrock aluminum pump
Old Jan 19, 2010 | 07:03 PM
Tyrel2018's Avatar
Car: 1989 Camaro RS
Engine: LO5 350
Axle/Gears: 3.42 posi
Re: Blew my water pump gasket yesterday....
it could be warped
Old Jan 19, 2010 | 09:43 PM
tom3's Avatar
Car: 88 Camaro
Engine: L98 350
Only problem I've had is with FelPro blue gaskets. If this is what you're using get a pair of old style black gaskets.
Old Jan 20, 2010 | 12:34 PM
thirdgen88's Avatar
Car: 1995 Corvette
Transmission: 6 spd Manual
Axle/Gears: Dana 44, 3:45:1
i always use blue RTV on both sides of the water pump gaskets.. clean the surface up real nice, wipe down with a brake-clean sprayed towel, and install with rtv-applied gaskets... get the pump bolted up, and torqued down... Then let it sit overnight so the RTV can cure. after that, go ahead and fill the system... Never had a problem doing it this way... You can get everything put back together, just wait to fill it up until the morning..
Old Jan 20, 2010 | 01:28 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
If you have been using permatex or some other sealant on them, don't.
Just use a blue fel-pro gasket, I've never had a problem with them.
To make installation easier, go to the hardware store and get some 3/8-16 x 3" studs to use in place of the water pump bolts.
Old Jan 20, 2010 | 03:49 PM
mbolte's Avatar
Car: 1987 Camaro
ok, I'll get some new gaskets...should I put them on dry or use some copper coat?
Old Jan 20, 2010 | 03:57 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
dry
Old Jan 20, 2010 | 04:31 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Dont use atv silicone on water pumps. Its slick, moves around, blows out easier under higher rpm, elevated psi and temps.
either dry paper gasket or i have been using a touch of thread paste pipe sealant and have had great results..
thats what GM uses on the LS oil pan gaskets where they intersect..
Old Jan 20, 2010 | 04:37 PM
mbolte's Avatar
Car: 1987 Camaro
Cool, thanks for the tips guys, I'll put them on dry hopefully this weekend when the weather doesn't suck
Old Jan 20, 2010 | 09:59 PM
EvilCartman's Avatar
Car: '82 Z28
Was the car fully warmed up when it blew? I blew out the rear plate gasket twice when I didn't let the car fully warm up and I'm guessing the thermostat wasn't open yet. Friend of mine kept blowing out gaskets, finally put a straight edge across the two mating surfaces and found it wasn't flat across.
Old Jan 20, 2010 | 11:46 PM
mbolte's Avatar
Car: 1987 Camaro
Ya, it was completely warm I was on the way back from a beer run and noticed the 210 temp when I pulled in
evilstuie
Jan 9, 2020 08:29 PM
Chuck84TA
Jul 15, 2016 09:05 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 22, 2015 05:36 AM
Dialed_In
Aug 20, 2015 01:45 PM
