383 question
Old Jan 21, 2010 | 04:57 PM
dkrider24's Avatar
383 question
ive got a 86 t.a with a 305 tpi engine in it. im buildin a 383, already got my block and machine work done to it. now id like to save a little bit of money and use my tpi system on my 383, is this a good idea or should i just save up and carb my 383? what all would i need to make this work, and what should i be expected hp wise? i kno ill probley need bigger injecters and random things. thanks
Old Jan 21, 2010 | 05:19 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
Re: 383 question
what are your emission laws where you are , some states if your car came with EFI you can't go to a carb you have to have factory EFI or better EFI .
Old Jan 22, 2010 | 08:16 PM
dkrider24's Avatar
Re: 383 question
i live in IL, i dont have to worry about that
Old Jan 22, 2010 | 08:50 PM
dkrider24's Avatar
Re: 383 question
and id rather not carb it if i dont have to. but if there is a big hp difference then i will
Old Jan 22, 2010 | 10:47 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Consider a Holley/Weiand Stealth Ram. It'll flow much better than your stock TPI, will handle a 383 with ease.
Old Jan 26, 2010 | 04:55 AM
t-topsavage's Avatar
Car: 1988 Camaro IROC-Z/28
Engine: L98 5.7L T.P.I, stroked 383
Transmission: turbo hydro-matic 700R4
Axle/Gears: Borg Warner 9 boltG80 2.77
Re: 383 question
i have a L98 T.P.I motor that i stroked to a 383 and yes im on the stock runners and intake.. works beautifully, not throwing out as much power as i would like but.. im looking at getting some new vortec heads and then the weiand stealth ram vortec intake manifold, its just on the stock tpi system the fuel goes into the the fuel rails driver side front of motor, the weiand is passanger side back motor. im not sure the best way to convert for that is my only problem...
~Peace
Old Jan 26, 2010 | 06:14 AM
danziger's Avatar
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Re: 383 question
I ran the stock TPI on a mild 383/700R4 in a 1990 Corvette. It may not have been the fastest car (258rwhp), but boy was it fun on the street. The huge low-to-mid torque hit was giggle-inducing, tire-melting fun. I will probably do it again when the stock engine starts to go in my Formula...
Old Jan 26, 2010 | 06:23 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 383 question
You just ditch the original TPI engine bay fuel lines and run new braided lines up the back of the engine to the HSR rails.Cleaner apperance and less heat in fuel
https://www.thirdgen.org/forums/alte...r-install.html
Old Jan 26, 2010 | 06:26 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: 383 question
Originally Posted by danziger
stock TPI on a mild 383/700R4 .. boy was it fun on the street. The huge low-to-mid torque hit was giggle-inducing, tire-melting fun.
Can't beat 500ft/lb of torque @4K .No more power after 5K but fun getting there
http://www.compcams.com/Community/Ar...?ID=1737510521
Old Jan 27, 2010 | 04:22 AM
Re: 383 question
vetteoz dude you rock, im new to this site and you have already answered and helped with just about everything haha.. thanks again man really appreciate it.
~Peace
Cameeeero
Sep 18, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
